Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th October 2005, 02:40 PM   #1
lhgin is offline lhgin  Malaysia
Default Topaz Isolation transformer question...
Hi guys,
I've just got a Topaz Isolation Transformer, model 91001-11. It's capable of handling 240V/120V input and also output.
I can successfully connect it in US with no problems at all. When I brought it back to Malaysia, which is 240V, I'm having difficulties to get it to work. The unit is originally wired for 110V operation. How should I wire the primary and secondary to get it to work in 240V?
Please help.
Many thanks!
Old 4th October 2005, 03:52 PM   #2
cocolino's Avatar
You have four 115V windings on this transformer, two each for primary and secondary.
You must wire the 2 primary windings in series, the same for the 2 secondary windings (if You want to have 240V in as well out).
The picture below is the 230V/240V wiring scheme for a Topaz transformer.
I`m not 100% sure if the number notations for the winding end points are the same on Your transformer but IŽd rather suspect so.
Hope it helps.
Christoph
STEAL the BEST - INVENT the REST
Old 4th October 2005, 04:20 PM   #3
cocolino's Avatar
BTW:
did You unscrew those aluminium "faceplates" yet (behind which are located the screw terminals for the windings)?
If I remember okay there should be an adhesive tag on the inside of one (or both?) of this plates showing a wiring scheme and notations for the screw terminals, just like something as in the picture above.
Christoph
Old 5th October 2005, 04:25 AM   #4
Thanks Cocolino for the help!
I opened it up and saw the windings. I'll try the windings as stated in your post.
Isolation Transformer Question Captn Dave Tubes / Valves 6 28th April 2009 03:30 PM
Isolation Transformer question Jack Torrance Power Supplies 7 2nd January 2007 08:37 AM
Topaz 5kVA Isolation Transformer ampsarus Swap Meet 1 7th November 2005 07:00 AM
Topaz Isolation Tranny lpd Tubes / Valves 3 14th June 2004 02:29 AM
Page generated in 0.07456 seconds (81.43% PHP - 18.57% MySQL) with 11 queries
