| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello all!
Just a quick question: Can i use a single sweep frequency (say, 1MHz) for all frequencies from 0 to (in this example) 1Mhz? Thank you
"There's something organic about a happy cloud of electrons" - Neutron Bob |
#2 |
your scope horizontal (sweep) axis is in mS or uS/div. You usually adjust the sweep speed to display the portion of signal you want to examine. 50Hz needs an opposite end of sweep scale from 200kHz. Q1. Is there a way to display signals below 10Hz so that they can be read?
regards Andrew T. |
#3 | |
I cant tell the time division :P
It's that i'm planning to make a simple scope based on vintage tubes ans schematics, and to simplify the sawtooth sweep generator, i would make it a single frequency unit. I know that for €150 i could buy a brand new scope, but it's taht thign that pushes us forward in DIY So, for instance, if i used a large frequency in relation to a smaller frequency, it would be displayed more times? Quote:
![]() Thank you
#4 |
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
Hi pinkmouse,
Broken link. For me anyway. -Chris |
#6 |
Hmm, worked last week, I'll see if I can find it again. It's the XYZ of scopes on the Tektronics site...
edit: Try this.
#7 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#8 |
IIRC-- you could amplify/divide a sweep signal to achieve the desired
voltage-rise-per-unit-time between the deflection plates. I would think there would be limits to this approach and at some point different sweep frequencies would be needed. It has been a long time since I thought about building a scope so this opinion may need a sanity/senility check D
intentionally blank |
#9 |
Thanks for the link pinkmouse, i'll read it
BTW, here's the project i'm following (the chassis is almost finished using an old mini-tower PC case as a basis - grind, weld, blá-blá). Having it (cross fingers) working would be great as i iwould then have a base for experimenting what i've learned and evolve as a bit of my own design. Hey, i even thought of a low slew rate opamp fed with a square-wave to make the sawtooth signal to feed the horizontal sweep plates Thank you all, good night http://www.electronixandmore.com/project/7.html
| Great deal on Digital scope. Is this enough scope? | hifimaker | Pass Labs | 1 | 1st May 2007 09:59 PM |
| DC fan speed regulating question | sunrise | Solid State | 23 | 7th August 2006 04:31 PM |
| harmonic sweep | koolscooby | Music | 5 | 8th January 2004 04:05 PM |
| Sweep Generators | yldouright | Swap Meet | 1 | 29th June 2003 01:53 PM |
| Page generated in 0.09763 seconds (79.54% PHP - 20.46% MySQL) with 10 queries |
