Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What is the most easy way to remove protection from copper wire
Old 21st September 2005, 07:19 PM   #1
luka is offline luka  Slovenia
luka's Avatar
Default What is the most easy way to remove protection from copper wire
I will have to solder many copper wires, so i would like to get some suggestions.
Thx
Old 21st September 2005, 07:45 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
I'll assume you mean removing the wire jacket from the wire. For that it's easiest to use wire strippers. Something like this for instance: http://www.partsexpress.com/pe/showd...number=360-015
Or you can get fancy and go for one that does it automatically: http://www.partsexpress.com/pe/showd...number=360-627
If you mean removing the varnish coating from magnetic wire then you'll need to scrape that off with a blade or use sandpaper. Also, some just melt off when you go to solder them.
Old 25th September 2005, 07:22 PM   #3
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Teflon insulated wire is easiest to strip with a thermal stripper:
http://www.omega.com/pptst/TW_TWC_STRIPALL.html
You might be able to find one used cheap. I found mine for $15.
I don't recommend this method for vinyl insulated wire- it stinks!
I_F
Old 26th September 2005, 10:47 AM   #4
luka's Avatar
what about some sort of liquid
Old 26th September 2005, 04:33 PM   #5
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
luka,
What wire are you trying to strip? Perhaps post a pic.
BWRX,
That second link for the stripper says "automatic". I wonder what they mean by that. My set doesn't seem to be very automatic.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 26th September 2005, 09:04 PM   #6
BWRX's Avatar
By automatic they mean that it cuts the jacket and then pulls it off as well. I have an old one that does the same thing and it really is quite nifty. But the simple ones work just as well and are cheaper.
Here's a quick mpg movie (about 5MB) I just made with my camera to show you how it works.
Please right click and save as: http://www.personal.psu.edu/users/b/...9/MOV01479.MPG
Old 26th September 2005, 09:24 PM   #7
Speakerholic
Cal Weldon's Avatar
Excellent flick.
Does the one in your movie work sideways? If not it sure looked like it.
Anyway, the pair I have looks identical to the one in the parts express link (except for colour), where you load the wire from the front not the side.
I am still wondering what the atuomatic part is.
Old 26th September 2005, 09:44 PM   #8
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
I_F
I use alot of teflon wire.. Where did you get this ? I need one.. totally..
Old 26th September 2005, 09:46 PM   #9
BWRX's Avatar
Yes, the one I have works sideways. I thought the automatic part was that it cuts and removes the jacket from the end of the wire. I could be wrong as I've never seen one of those front loaders in action.
Old 26th September 2005, 11:08 PM   #10
I_Forgot's Avatar
Teflon wire is great stuff. The insulation doesn't burn or melt while soldering so the result is much neater than PVC wire.
I picked my wire stripper up at an electronic swapmeet in Dallas a couple years ago. Look for amateur radio groups in your area- they have a lot of swapmeets where you can find all sorts of useful stuff for pennies on the dollar.
The electric stripper is quite similar in construction to solder "guns". There send a lot of current through a pair of "blades" to heat them up. You might be able to make something like it out of an old solder gun.
I_F
What is the most easy way to remove protection from copper wireHide this!Advertise here!
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 10:32 PM
WTB: 6N or 7N pure copper wire for TVC cartman Swap Meet 0 23rd October 2008 11:43 AM
Failure with easy spk protection circuit bigpanda Solid State 20 19th August 2004 05:24 AM
Copyright ©1999-2017 diyAudio
