inductor value - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th September 2002, 09:56 PM   #1
SvErD is offline SvErD  Norway
SvErD's Avatar
Default inductor value
Hello all
I've got a few of these inductors and I wondered if anyone would be so kind and help me find out the inductance :-).
The dcR is close to zero as they are not wirewound but 25mm wide band(foil?). Average coil dia is ~40mm. It's 1--20 turns, a bit difficult to see.
I don't suffer from insanity, I enjoy every minute of it!
Old 30th September 2002, 09:58 PM   #2
SvErD's Avatar
That should be 15-20 turns
Old 30th September 2002, 10:40 PM   #3
Send a message via ICQ to ThingyNess
If you download a program like speaker workshop (www.audua.com) and make a simple jig, you can easily measure the inductance (at least between 10hz -> 20khz) yourself, along with the DC resistance, and therefore Q factor of the inductor.
Done right, the speaker workshop way is pretty darned accurate, and very inexpensive.
Old 30th September 2002, 11:04 PM   #4
SvErD's Avatar
Thanks a lot, i'll try that
Old 30th September 2002, 11:08 PM   #5
One other quick note - the process of making the required jig is documented in the speaker workshop help file.
(people have been known to miss this.)
Old 30th September 2002, 11:22 PM   #6
SvErD's Avatar
As did I. Thanks again. I'll try it tomorrow.
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Inductor DCR ? mace Multi-Way 3 9th September 2007 10:41 PM
Inductor lot 875+ for the DIY RAW Multi-Way 1 14th August 2007 01:23 AM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
WTB: INductor:0.2, 0.25, 0.33& 0.9, CAP: 2.7uF&8.2uF gengis Swap Meet 0 6th July 2006 08:46 PM
Copyright 1999-2017 diyAudio
