Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th September 2005, 02:08 PM   #1
Default Question about capacitor replacement
Ok , I have a bad cap in a epson video projector , it is a 150 uf 400 v
but I don't have one with that rating . I do have one that will fit size wise but has a spec of 100uf 400 v , question is could I use the lower uf one to test the unit before ordering the 150uf or would the 100 uf even pass to use on a longer term than just testing .Or what side effects of using a lower uf cap would I expect to see ? Was told that it had a puff of smoke and tripped the circuit breaker to the room so not sure if the cap is all that is bad with it so don't want to put too much in it yet.Should the cap being bad trip the breaker before even blowing the built in fuse on the unit ?
Amplifier main capacitor replacement - voltage question Tino Pass Labs 22 12th November 2008 04:27 PM
Capacitor Replacement - HELP PLEASE! SoundQuest Solid State 1 2nd April 2008 12:36 AM
Capacitor replacement question spooney Car Audio 3 15th September 2007 07:23 PM
Capacitor replacement bulgin Solid State 11 2nd August 2006 09:08 PM
Capacitor Replacement on Spectro Amp ralph-bway Solid State 2 17th October 2003 03:52 AM
Page generated in 0.05661 seconds (80.80% PHP - 19.20% MySQL) with 10 queries
