Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
High capacitance from small packages for analog decoupling?
Old 19th September 2005, 11:33 AM   #1
Petter is offline Petter
Default High capacitance from small packages for analog decoupling?
I am currently building a project where I have trouble finding room for all the capacitors I require. I am most worried about the analog section where the datasheet suggests I need 10-50uF in places. The vendor's evaluation module uses high quality through-hole Electrolytics, but due to the geometry of my layout I need to use SMD.
High capacitance from small packages is what I need. I have found film devices which offer up to 1uF in SMD1210. However stacking 10 such units is not desirable so my current plan is to stack say:
1. Silver Mica SMD1210 device
2. two film SMD1210 devices on top
3. one AVC TacMicrochip device on top of that again for the bulk capacitance. http://www.avxcorp.com/docs/catalogs/taclp.pdf
The AVX device seems to offer very high capacitance, low volume, low leakage and reasonable impedances and 15uF in 10V (I operate at 5V analog). What I am not so sure about is the dielectric loss.
In the past, Tantalum capacitors seemed to be shunned by users due to their failure modes (short) and often catastrophic failures. What I have yet to find is a consideration of how well these units perform in audio. These units seem ideal for my needs - your comments on this matter would be greatly appreciated.
Petter
Old 20th September 2005, 03:09 PM   #2
From elsewhere someone recommended Panasonic SP (Specialty Polymer). These seem like fine units but are rather large at SMD 7343 (7.3mm by 4.3mm). I have found film devices I could use beneath such units but with limited capacitance of a few uF.
I would still be pleased for other suggestions.
Old 21st September 2005, 11:08 AM   #3
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Try the murata GRM32ER60J107ME20
Ceramic, 100uF, 6.3V, X5R, 1210
ESR=1mOhm, ESL=2nH, fres=400Khz
TDK makes a similar devise, but I can not remember the product number.
I hope this helps you
\Jens
Old 21st September 2005, 12:50 PM   #4
More info here:
http://ur-group.co.uk/artesyn/cd/pdf...n_pth12050.pdf
\Jens
Old 21st September 2005, 01:35 PM   #5
Loial is offline Loial  Sweden
Why not use SMD electrolytics?
Old 23rd September 2005, 02:25 PM   #6
I am using ceramics on the digital side, but am worried about them for the analog side, particularly the low capacitance units.
SMD electrolytics work, but I was looking for something even smaller + they seem harder to handsolder.
Petter
Old 23rd September 2005, 05:38 PM   #7
I agree small SMD electrolytics are a real pain in the *** to solder ( and desolder is eaven more tricky... )
I just remembered that I've got a bunch of 6,8 uF 50V ceramic caps ( actually two caps in one ), measuring approx. 5*7*5 mm.
Really easy to solder, I attached an image of it.
Petter - I could send you a few if you'd like, for some coffe-money 5-10 pcs? Where in scandinavia do you live?
By the way... with "small packages" - how small do you mean?
Old 25th September 2005, 08:43 AM   #8
How small:
SMD1206 or 1210 would be really good for me but if really large film units can be found, larger is OK. The only problem is that the 1210 units I plan to use are 1uF and the largest "normal" SMD sticks I have seen (in film) have been only a couple of uF thus not really worth the effort as stacking 5 of the small ones is probably just as good as using the big ones + don't cause the same layout issues give that things are getting so tight.
Petter
High capacitance from small packages for analog decoupling?Hide this!Advertise here!
Capacitance to high? wboyd Chip Amps 10 14th March 2006 07:52 PM
Sound-relevant effects in decoupling caps for analog nodes/measurement methods capslock Parts 20 6th August 2002 01:30 PM
High Frequency Rolloff in software packages jteef Multi-Way 4 6th June 2002 12:51 PM
High capacitance KingsLaw Multi-Way 1 14th December 2001 05:28 AM
