Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th September 2005, 11:29 PM   #1
roger-k is offline roger-k  Norway
Default 100 ohm pot for preamp?
I will make this preamp:
http://www.tcaas.btinternet.co.uk/jlhmodpre.htm
It is hard for me to get the 100 ohm pot for the balance-controll.
Any who know about a place where I can buy 100ohm pot which is panel mounted?
Or can I solve this in an other way?
Roger
Old 18th September 2005, 01:33 AM   #2
anatech is offline anatech  Canada
anatech's Avatar
Interesting. I would have assumed 100K. At 100R, the coupling caps are a bit small. Are you sure it isn't a misprint?
-Chris
Old 18th September 2005, 02:01 AM   #3
hughmon is offline hughmon  United States
Any particular reason for using an inverting phono stage?? Or do you just plan to build from the line level on??
Old 18th September 2005, 08:42 AM   #4
I do not have the skills to confirm that 100r is correct or if it is a misprint.
However, try leaving that connection empty at first build and then insert a 100r resistor to ground and measure the amp gain. Then use a 50r (100//100) to measure the in balance gain and finally connect the cap to ground (equivalent to balance control way off to left) and again check gain.
If the 100r is correct the gain should go about +3db to -10db relative to the 50r measurement.
regards Andrew T.
Old 18th September 2005, 09:47 AM   #5
Default 100ohm is correct, not misprint
It is 100 ohm. This is not a misprint.
"Fine balance between channels is obtained by adjusting the 100ohm balance potentiometer in the output stage"
This text is a copy from the intenet page:
Regards Roger
Roger
Old 18th September 2005, 02:15 PM   #6
anatech's Avatar
There will be some frequency problems with that value then. As in, too much bass in the lowered channel. Oh well.
-Chris
Old 18th September 2005, 04:27 PM   #7
moamps is offline moamps  Croatia
Default Re: 100 ohm pot for preamp?
http://no.farnell.com/jsp/endecaSear...&Ntk=gensearch
Old 19th September 2005, 09:51 AM   #8
moamps:
Thanks for the reply. Now I have order the pots from farnell.
hughmon:
Yes, I will not make the phono stage.
Regards Roger
Roger
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Page generated in 0.08297 seconds (77.61% PHP - 22.39% MySQL) with 10 queries
