Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Output voltage question!
Old 14th September 2005, 07:29 AM   #1
pomes131 is offline pomes131  United States
Default Output voltage question!
Most good processors advertise 5-6v(and up) output signal..both of my amps input sensitivity are 250mV-4V..does this mean that I have to find a processor with a 4V max output?? Also, some say 7V max output..does this mean its adjustable?? Thanks in advance..........
Old 17th September 2005, 06:05 AM   #2
ocool_15 is offline ocool_15  Canada
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
It would mean that at 4V your amp should be making full power.
the max of 7V may be indicating peak voltage so 7/1.414= 4.95V rms signal but I'm not sure if thats what they are indicating.
Old 18th September 2005, 09:22 AM   #3
I think the maximum voltages quoted coming from analogue processors and amps is the maximum just before clipping and/or just as the distortion starts to rise significantly.
With digital ancilliaries the maximum signal out is when the output is at 0db in the digital domain.
With both types a typical high volume signal output is likely to be in the range 10db to 20db below these maxima. ie. 0.5V is -20db relative to 5V.
With quieter music the signal out is more likely to be another 20db to 40db below the normal outputs. i.e. 5mV (-60db) to 150mV (-30db). This is why noise (or rather the lack of it) becomes important at these very low signal levels.
Your sensitive amp with a requirement for 250mV for maximum output will require more attenuation of the signal than the less sensitive amp that needs 4V for maximum output (this seems more like PA equipment).
Most domestic digital equipment has a maximum output of about 2V and would need some amplification to suit the 4V amp IF YOU WANT TO DRIVE that amp to MAXIMUM output.
regards Andrew T.
Old 19th September 2005, 03:22 AM   #4
Hes looking at "5-6v(and up) output signal" so his amps would make full power before the processor puts out its max signal.
Output voltage question!Hide this!Advertise here!
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 06:17 AM
DC voltage on output durxter Chip Amps 20 6th March 2005 07:25 PM
P27 Output Voltage rayban68 Solid State 0 6th October 2004 07:19 PM
Stupid question about voltage and output power Cro maniac Chip Amps 7 6th May 2004 12:33 PM
