Need help with simple project
Hiya,
I'm hoping one of you guys can give me a hand with a project im working on. after browsing the forums it seems like it should be pretty easy for you. Ive made some regular electronic projects but im pretty new to audio electronics.
Basicaly i have a problem where i have lot of audio outputs from various sources such as DVD player, VHS player, TV, PS2, Laptop, Desktop, Stereo. and have a good few inputs such as Surround sound, Headset, Wireless headphones, TV etc etc. At the moment i am constantly crawling under and behind my desk when i want to change what im hearing and how.
So, I have come up with the idea of having an audio junction box, where i have a plastic enclosure box, on one side i have a row of inputs phono and 3.5mm jack, and on the other side I have a row of 3.5mm outputs, all of which has its own switch so i can turn in/outputs on and off.
Here is a picture of the basic layout, but im not sure of what it will do to the sound quality and if i need some sort of op amp or what.
Just connect your inputs to a rotary switch and your outputs to one as well.
2 pole 6 position break before make like these will do the job.
http://www.altronics.com.au/index.asp?area=item&id=S3022
Inputs to the outside connectors (input sw) > out from the inside 2 connectors (input sw) > inside 2 connectors (output sw) > outside connectors (output sw)
Better than having individual switches that you can forget to turn off and have 4 sources playing at once.
Keep your left channel to 1 pole and right channel to the other pole. You've got the idea but make sure you don't join the RCA inputs as you have shown.... treat it the same as the 3.5mm jacks.
All the grounds on the inputs and outputs are joined together at 1 point and bypass the switches.... only hot wires on the switches.
Hmm, Not really sure what you mean. should the RCA have their own switch in that case?
And do you mean all the ground wires should connect together not touching the switches?
What I mean is that you only connect the centre pin of the RCA to the switch.... same as the 3.5mm.
Ground wires by pass the switch all together and all connect to 1 point.
Like this.... right to right (red), left to left (blue), ground to ground (black).
Splash said:
Ah ok, 2 of them have continuity so im guessing the other one is dummy?
No in fact the two that have continuity are the same "pin" since they are connected together, and the other one is the other pin. The reason that there are 3 pins on the package is just to make it more mechanically secure once soldered in place.
Another possibility is that the extra pin is connected to the signal pin only when nothing is plugged into the jack. The connection is broken once a plug is inserted. This type of jack is often used to turn off a built-in speaker when a headphone is plugged in.
Sorry to say it, but you really can't make this work with mono jacks.
