| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Ok so in my new reciever one of the lights for the dials has burnt out. So I was thining wouldnt it be cool to have the dials blue instead of white. So I start checking some stuff and find out that the stock bulbs run off of 7.5vac and I want to put in leds which at 2.1-3.6vdc. My question is how do I convert the ac current to dc current? Is there a simple circuit board I can make to do this or would I just be better off looking for a dc rail in the amp.
If you cant mod it right. Dont mod it at all. |
#2 |
Ok I have figured out that I need to use a rectifier, but what kind should I use? Should I use a smoothing circuit for just hooking up leds? Can someone please explain this to me.
#3 |
Please do not be offended as this is intended with good will:
You are going to kill yourself if you start messing around inside electronics and don't know what you are doing. Go and buy (or download) a book about electronics fundamentals and read it three times, then see if you still need to ask the question.
Jesus loves you. |
#4 |
Read your own sig
#5 |
I know what I am doing. I have worked on so many electronics it is not funny. I dont know why you would thin I would kill myself other then if I touched a cap or messed with the high voltage rails. I am not an idiot I know what is what. We are takling about the circuit that runs the lamps not the *******g main power. I mean yeah if I wanted to go from a normal wall socket 120vac to a 12vdc amp I would run a psu and do it that way but what I want to build only pulls .240a so I dont *******g need a supper beefy board.
And what does my sig have to do with anything. I am going to mod it so I want to know how to mod it right.
#6 |
To put it bluntly, if you don't know how to do this yourself, you have some reading to do, but anyway:
You need minimum 1 resistor and 1 diode. Connect the resistor in series with the diode and the LED and just connect that across the AC line. Calculate the resistor using Ohm's law. However, this will leave the LED flashing at 30 Hz. A more spphisticated solution uses a rectifier bridge and electrolytic capacitor before the resistor, just like in any cheap wall-wart. Now, figure out the rest yourself. If you can't, you won't be able to troubleshoot either, so then don't bother... Rune
Do wizards use spell checkers? |
#7 | |
Calm down already.
Jesus loves you. |
#8 |
Use a blue permanent maker to paint the lamp blue. You shouldn't use a soldering iron on anything that gets within 100 yards of 120V AC
#9 | |
Why do you always have to complicate things? ![]() The solution is obvious! Buy a blue lamp Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#10 |
This is DIY stuff, and he wants to mod it. What are you thinking!
| Make it worse to make it better??? | moray james | Planars & Exotics | 23 | 12th May 2008 12:08 PM |
| What to make? | Mayday | Tubes / Valves | 3 | 5th December 2006 04:20 AM |
| Trying to make a car amp. got a big different from the.... ? | alan8888 | Solid State | 0 | 4th August 2005 07:25 AM |
| How make make a microchip, from a program? | multiplexor | Everything Else | 1 | 20th February 2004 02:24 PM |
| Page generated in 0.09740 seconds (81.07% PHP - 18.93% MySQL) with 10 queries |
