Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th September 2005, 10:24 PM   #11
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by Brian Donaldson
This is DIY stuff, and he wants to mod it. What are you thinking!
Do you really have to turn nasty just because my solution is better than yours?
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 10th September 2005, 10:28 PM   #12
EchoWars's Avatar
The LED's will run off of AC just fine if you put a diode in there to limit the reverse voltage. That and a resistor sized to give the current through the diode that you need.
The larger problem with replacing dial lamps with LED's is the narrow light emitting pattern from the LED's. They will not light up an area like an incandescent lamp.
There are some companies that sell small LED 'bulbs' which contain small clusters of LED's designed to disperse the light somewhat. I think Digikey has a few, but I don't know how well they work.
Old 12th September 2005, 07:14 PM   #13
Use a diode and resistor in series with the LED. For a typical 3.6V LED, to run @ 7V use a 330 or 470 ohm resistor to limit current depending on how bright you want and how much the LED can handle.
Too keep the LED from blinking at 60HZ, put a 100uf cap across + and - leads of the LED
Just like rectifying AC on a Powersupply to turn to DC, on a smaller scale.
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 12:08 PM
What to make? Mayday Tubes / Valves 3 5th December 2006 04:20 AM
Trying to make a car amp. got a big different from the.... ? alan8888 Solid State 0 4th August 2005 07:25 AM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 02:24 PM
Page generated in 0.07148 seconds (66.04% PHP - 33.96% MySQL) with 10 queries
