Where to get pot shaft extension? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th September 2012, 06:31 PM   #31
Another idea which works well for me. Look for a 60Amp (or similar)
terminal strip similar to the one in the pic.
The brass inserts are perfect as shaft couplers, with about
a 1/4" dia hole and 2 set screws!
Easily available in most parts of the world and one terminal strip yields a
lifetime supply of couplers for me.
12 Section 80 Amp Terminal Strip
The best quality inserts are found in ceramic terminal blocks.
Ceramic Terminal Blocks - High Temperature
Old 17th September 2012, 06:50 PM   #32
redjr is offline redjr  United States
Very smart quad. Great idea. Thanks for the suggestion.
redjr
Old 17th September 2012, 07:16 PM   #33
von Ah is offline von Ah  United States
von Ah's Avatar
Here is where I picked up some a few months ago:
www.surplussales.com Shaft Couplings
Lotsa other nifty bits from the same vendor...
Old 17th September 2012, 07:39 PM   #34
Thanks von. Good stuff.
redjr
Old 2nd December 2013, 10:22 AM   #35
nnx is offline nnx
Default Home made extension.
I just made some extensions out of 6mm aluminium rod which is filed down on both sides to fit the slot in the pot shaft. Two small holes are drilled and the extension is riveted to the pot shaft using small nails or pieces of wire as rivets. Heat- shrink covers the finished joint. It is a bit tricky to get it straight, but the finished product seems to be worth the effort. Please enjoy!
Old 2nd December 2013, 02:20 PM   #36
AndrewT is online now AndrewT  Scotland
Neat filing job.
Quite a bit easier than a female knurled coupling !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th December 2013, 01:01 AM   #37
nnx is offline nnx
Thank you Andrew, the filing of the shaft is the tricky part. It needs to be fairly symmetrical, otherwise the whole thing will wobble. It would be easier if you used a small mill.
A knurled female coupling....? Hmmm....
Well, I guess you could make one out of an internally splined plastic knob by drilling a hole for the shaft in the opposite end and then gluing the shaft to the knob. I will try that next time!
Old 12th January 2014, 02:00 PM   #38
Hi, spent about an hour on the lathe and micro mill to make theses for my Naim Nac42.5 clone.
The rear brackets (float) on a neoprene pad, because I found it impossible to centre the connector with a pot with a flat on the shaft and they now rotate really smoothly, the front bracket has a pressed in 3 x 10 x 6 sealed bearing carrying the shaft. Bit of a pain but worth it in the end.
086 by robertsearby, on Flickr
Old 12th July 2015, 04:40 AM   #39
thoglette's Avatar
If you're in .au or .nz Rod Elliot sells a a 220mm unit with all the bits
See ESP - Extension Shaft Purchase Information
Old 12th July 2015, 10:41 PM   #40
Default Need FLEXIBLE 1/4" Coupling/shaft
Guys,
I'm changing the faceplate on a preamp I built a while back and would like to move the knob/bushing for the function switch over about three inches on the faceplate. The switch itself is mounted to a PC board attached directly to the input jacks on the back panel. The switch/knob are currently attached to each other via a straight 1/4" shaft about nine inches long.
I remember that "someone" used to make flexible, coiled 1/4", "spring-like" material that would probably work. Anyone have some? Or Apex (or someone else); do you still have any more of those "1/4" universal joint couplers" you mentioned a few years back?? Would need two "sets".
THANKS
Charles
Can I adapt the shaft of a pot? vvangelovski Parts 7 23rd May 2009 05:15 PM
WTB: Black 1/4"-shaft pots r0cket- Swap Meet 0 27th April 2004 06:33 AM
Where to get shaft extenders r0cket- Parts 6 23rd April 2004 03:02 AM
shaft extender JAZZ2250 Parts 4 7th July 2003 04:01 PM
Source for Shaft Extenders Panelhead Parts 9 14th February 2003 10:36 AM
Copyright 1999-2017 diyAudio
