Where to get pot shaft extension? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th August 2011, 06:02 PM   #21
Originally Posted by Peter Daniel View Post
I'm using 1/4" long drill bit and cut it to the size. On front panel (for new bushing) I use the bushing from any pot or switch that fits nicely over 1/4" drill bit, the use of some grease is recommended here., On the potentiometer side, for connection between new shaft and pot you can use aluminum standoff with 1/4" hole drilled through (2 screws can be used to hold shafts in a standoff) or any other metal tube that fits tight over shafts.
sorry for bumping old thread..
peter, how do you make the shaft sits firmly on the front panel while rotating? i still can't grasp the whole idea by reading your words..i'm planning to make an extension shaft for my potentiometer too
Old 14th August 2011, 06:08 PM   #22
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I'm not Peter but I have seen bushings, somewhere
but I also need to fix this for my own project
but drilling a precision hole should do
I might drill smaller
and then use a small needle file
and give a tiny amount of grease
tho, I think a press fit nylon bush would be optimal
those I haven't seen anywhere
back/forth movement is held in place by pot/extension fixing
be aware there may be both 6mm and inches equivalent, which is 6.3mm
Old 15th August 2011, 11:16 AM   #23
thanks for the advise tinitus, i'll try that out..
Old 15th August 2011, 11:43 AM   #24
jackinnj's Avatar
Mouser has the press-fit bushings made by Keystone, but they might not be in the catalog.
Old 15th August 2011, 06:09 PM   #25
Send a message via AIM to HuntTheShunt Send a message via MSN to HuntTheShunt Send a message via Yahoo to HuntTheShunt
Default Wow a 9 year old thread!
Good to see forum is going strong
DiyAudio
Old 16th August 2011, 01:28 AM   #26
Also not Peter....but I have used some brass tubing barbs as sleeves:
Double Barb Fittings for Tubing: Male Connector
Just drill it to the exact size, cut the unused barb part and press-fit or thread into the faceplate.
Brass is ideal as it is 'self-lubricating'.
I also have one pre-amp with a stainless shaft turning directly in a precision hole in the 10mm aluminum faceplate. It binds without oil/grease.
Old 16th August 2011, 01:47 AM   #27
shaft extension, EXT-KIT-26
Audio Catalog
Old 12th September 2012, 08:29 PM   #28
redjr is offline redjr  United States
Now a 12 yr old thread! Thanks Scott. Placed an order today.
redjr
Old 12th September 2012, 11:05 PM   #29
Here is a product to extend shafts: Set Screw Stainless Steel Shaft Couplings - Stainless Steel Shaft Coupling Company. , your local building supply store should carry 1/4" round alumimium rods. As a support through a panel I would use standard nylon snap bushings. E
Old 12th September 2012, 11:32 PM   #30
Thanks for the link mickeymoose. Perfect! Next time in HomeDepot I'm going to have a look around to see if they stock these , or similar couplers and small diameter tubes. Before Scott posted his link, I went in search of these extender rods and couplers. Interestingly, I could not find them at any of the parts houses I use. ie. Mouser, Newark, etc. Don't they exist as a common part - an accessory that may need to be used with pots in general? They are used in many commercial amps.
I built many a Heathkit in my day, and some even used these small hollow/solid tubes and couplers. Why are they so hard to find today? Like I said, I finally placed an order for some today via the link provided by Scott.
Rick
redjr
Can I adapt the shaft of a pot? vvangelovski Parts 7 23rd May 2009 05:15 PM
WTB: Black 1/4"-shaft pots r0cket- Swap Meet 0 27th April 2004 06:33 AM
Where to get shaft extenders r0cket- Parts 6 23rd April 2004 03:02 AM
shaft extender JAZZ2250 Parts 4 7th July 2003 04:01 PM
Source for Shaft Extenders Panelhead Parts 9 14th February 2003 10:36 AM
Copyright 1999-2017 diyAudio
