Where to get pot shaft extension? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th April 2005, 07:07 AM   #11
Send a message via AIM to HuntTheShunt Send a message via MSN to HuntTheShunt Send a message via Yahoo to HuntTheShunt
Default What do you mean?
> Post #11
Use the shafts and couplers from an erector set.
I dont understand the above reference
The extensions at http://sound.westhost.com/purchase.htm look the best but at $21 dollars seem expensive.
Is there a cheaper alternative?
DiyAudio
Old 11th April 2005, 12:13 PM   #12
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Dome tent glassfiber sticks.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 11th April 2005, 01:03 PM   #13
also Jameco has them for about 4$ each.
- mantisory
Old 11th April 2005, 01:54 PM   #14
jackinnj's Avatar
these are stainless steel --
http://www.smallparts.com/products/d...tions/crsx.cfm
Old 11th April 2005, 02:56 PM   #15
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
The easiest way to implement shaft extender is to use 1/2 OD / 1/4 ID plastic washer for bushing, 1/4 brass rod for extention, and 1/4 ID PCV water pipe for coupling. All materials available at Home Depot, or your preferred building materials supplier.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th April 2005, 09:01 PM   #16
antomas is offline antomas  Europe
Digikey sell part RP383-ND or similar. Unfortunately, they don't have a metric (6mm) equivalent for the european guys...
Massimo
Old 12th April 2005, 11:29 PM   #17
Massimo
This is still not a bigh deal. Another way to do it is use a thin piece of FR-4 material (PCB material) or thin plastic, drill it through with 6mm drill, and attach to the panel with double sided tape or glue. The panel opening has to be larger than 6mm.
I fixed this way an off center hole in one of my prototypes and it worked just fine
www.audiosector.com
Old 13th April 2005, 02:13 PM   #18
Default In doubt
Dear Peter, thanks a lot for your (as usual informative) answer.
Just for curiosity, a few years ago I bought a few of the Digikey washers; the material (nylon?) they are made of looks very smooth and appropriate for the purpose. I have instead some doubts about FR-4 (epoxy?). Correct if I'm wrong, but it seems a bit abrasive to me...
Thanks a lot,
Massimo
Old 13th April 2005, 04:16 PM   #19
In my case, I used very thin piece (0.025") and with brass shaft, it acted as a very nice bushing (providing the hole was right fit)).
This material is much softer than brass (as it's not pure epoxy, but mostly fibre).
www.audiosector.com
Old 15th April 2005, 02:11 AM   #20
Apex Jr is offline Apex Jr  United States
Default Shaft Extention
Hi Guys...
I was just a a deal today and found a few things that
might interest this Group.
17 ea 1/4" Shaft couplers square unit w/ 2 -1/4" holes
each side but NO set screws.. there $1.50ea
6 ea 1/4" Universal Joints 1/4" both sides there $2.50ea
I do have a $20.00 minimum order but thought someone
might be able to use these. email me directly
steve.apexjr@prodigy.net
Check my website for maybe other items of interest
www.apexjr.com
Steve @ Apex Jr.
Can I adapt the shaft of a pot? vvangelovski Parts 7 23rd May 2009 06:15 PM
WTB: Black 1/4"-shaft pots r0cket- Swap Meet 0 27th April 2004 07:33 AM
Where to get shaft extenders r0cket- Parts 6 23rd April 2004 04:02 AM
shaft extender JAZZ2250 Parts 4 7th July 2003 05:01 PM
Source for Shaft Extenders Panelhead Parts 9 14th February 2003 11:36 AM
Copyright ©1999-2017 diyAudio
