Where to get pot shaft extension? Where to get pot shaft extension? - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th September 2002, 02:53 AM   #1
Dustin Haug is offline Dustin Haug
Default Where to get pot shaft extension?
I searched the forum, digikey, Michael Percy, and ApexJr with no luck so far. Where are you guys getting them?
Also anybody got any good pics of implementation. What I'm wondering is what's the best way to secure the shaft at the front plate so that it feels stable. Will I need a bearing or just run it through the hole and leave it at that.
Old 27th September 2002, 03:17 AM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Where to get pot shaft extension? Send a message via AIM to Peter Daniel
I'm using 1/4" long drill bit and cut it to the size. On front panel (for new bushing) I use the bushing from any pot or switch that fits nicely over 1/4" drill bit, the use of some grease is recommended here., On the potentiometer side, for connection between new shaft and pot you can use aluminum standoff with 1/4" hole drilled through (2 screws can be used to hold shafts in a standoff) or any other metal tube that fits tight over shafts.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th September 2002, 04:16 AM   #3
ThingyNess is offline ThingyNess  Canada
Send a message via ICQ to ThingyNess
http://sound.westhost.com/purchase.htm
Look for the "rotary switch extension shaft"
It should work great for pots too.
Old 27th September 2002, 04:40 AM   #4
Jocko Homo is offline Jocko Homo  United States
Banned
They make panel shaft bushings that support it on the front end. I have lots extra, if you need some.
Jocko
Old 27th September 2002, 07:40 AM   #5
yves is offline yves
Default why not...
... chopsticks?
You can slice off at an angle, the part that slots into the actual
pot handle and use hot melt on the other end
of the chopstick to glue to the knob.
A cheapskate idea, I hv not tried it though.
Yv
Old 27th September 2002, 07:52 AM   #6
Christer is offline Christer  Sweden
Shouldn't be too difficult to make an extension shaft, otherwise
have a look at
http://www.schuro.de/preisl-achsverb.htm
They have both extension shafts and "Kardanlenke" and
whatever you could dream of for your pots.
Old 27th September 2002, 12:19 PM   #7
jackinnj is offline jackinnj  United States
jackinnj's Avatar
also www.smallparts.com
Old 27th September 2002, 01:26 PM   #8
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default SHAFT
Hello,
You will need a shaft coupler at both ends which I suppose can be had from any of the sources mentioned.
Frank
Old 27th September 2002, 10:16 PM   #9
Apex Jr is offline Apex Jr  United States
Default Pot extentions
Dustin..........
I have a couple of 1/4" hole 5 1/4" length
shaft extentions in stock. Not everything I
stock is listed on the website. If interested
just let me know
Steve
Apex Jr
Old 27th September 2002, 11:50 PM   #10
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Use the shafts and couplers from an erector set.
Where to get pot shaft extension?Hide this!Advertise here!
Can I adapt the shaft of a pot? vvangelovski Parts 7 23rd May 2009 05:15 PM
WTB: Black 1/4"-shaft pots r0cket- Swap Meet 0 27th April 2004 06:33 AM
Where to get shaft extenders r0cket- Parts 6 23rd April 2004 03:02 AM
shaft extender JAZZ2250 Parts 4 7th July 2003 04:01 PM
Source for Shaft Extenders Panelhead Parts 9 14th February 2003 10:36 AM
Copyright ©1999-2017 diyAudio
