| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have designed a Software programmable active filter(analog) .The picture shows one channel of the finished circuit.
It is a 2-way Linkwitz-Riley configuration(24dB/oct).The devices shown on the blue sockets have 4 software adjustable potentiometers inside each one,by tying the wiper to one end of the pot you create an adjustable resistor.Different crossover points are achived by changing the resistor values(software controlled),256 discrete resistor values can be programmed(approx. 100hz crossover step resolution). I am using a "Basic Stamp"microcontroller to program the resistor values.I am using the "I2C" protocol for communication with the digital pots.The quad pots are from Analog Devices(part number is AD5263). It is my intention to further develop this project and have some PC boards made up in the near future.I will share the details for those who have an interest in this x-over.I do not have any formal documentation at this point,my main objective was to get the prototype built and get some initial data. My initial bench tests of the prototype are very positive,It looks like the channel balance is within .2 db between the LP/HP sections at the programmed crossover point. All comments are welcome. Regards Bob C. |
#2 |
Rob, I am definitely interested.
I will be in touch! Very cool!
Less pulp more juice Twisted Pear Audio. |
#3 |
I am also very, very interested.
#4 |
Very interesting
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#5 |
Electrons are yellow and more is better!
Very neat
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
PA: Your FDNR filter board could accomodate both techniques.The end user could have either a software programmable filter ,or by leaving out the digital pots and installing fixed value resistors,You have a conventional active filter. Bob C.
#7 |
Good work, let me know when you want to design the PCB -- Jack
#8 |
Hi Bob,
This is going to be really cool. I am working on my PCB with the parts you mentioned. I am about 80% done I would say. The only issues left to resolve for me are the ones related to the PIC itself and human interface. ![]() Cheers! Russ
#9 |
How good do these digi pots sound? Or it doesn't matter?
#10 |
Well they should sound fine, the specs are good. Bob has actually heard them, so I will let him answer based on experience.
![]() Cheers! Russ
| Programmable digital crossover | diypole | Multi-Way | 5 | 19th June 2009 08:21 PM |
| Anybody used a FPAA (field programmable analog array)? | kuroguy | Solid State | 4 | 27th May 2009 10:18 PM |
| Does this Programmable DSP Crossover Have Good Potential for Audio??? | loudandclear | Multi-Way | 1 | 16th November 2005 07:24 AM |
| Analog active xover | JensRasmussen | Multi-Way | 36 | 3rd May 2004 04:50 PM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 02:29 AM |
| Page generated in 0.12451 seconds (73.38% PHP - 26.62% MySQL) with 11 queries |
