Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th August 2005, 03:46 PM   #11
Did it Himself
richie00boy's Avatar
I thought it was Sodium Hydroxide, just checking. Might try acetone though just to see. NaoH on it's own seems to leave a film behind.
Paint shop? The stuff I use is drain cleaner.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 29th August 2005, 07:29 PM   #12
mzzj is offline mzzj  Finland
Originally posted by richie00boy
I . NaoH on it's own seems to leave a film behind. ... The stuff I use is drain cleaner.
Impure NaOH or something else mixed to drain cleaner?
I have used 2% NaOH and result is as clean as possible. Leave soaking for 2-15mins and rinse with hot tap water after NaOH and you should be done.
Steel wool or abrasive paper takes years to remove etch resist what we use at local univ. especially if I exposure bit longish time(paper mask for example) Maybe that resist is stronger than some others, it is also negative instead of usual? positive resist.
After drilling i use also steel wool to remove drilling burrs
Old 29th August 2005, 07:43 PM   #13
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
If it is sold as "drain cleaner", it might have some other additives...
Over here we buy it at the paint shop as "caustic soda",- also used for paint stripping and heavy duty cleaning
( and beleive i t or not: to make "lutefisk"-- dried cod soaked in lye, then rinsed for a couple of days in water.... a well known norwegian delicacy, mostly used around x-mas time.... and-- it is no joke !!!!!)
Old 29th August 2005, 08:05 PM   #14
We eat here that NaOH-cod also
but Swedish rotten herring(fermented) is absolute no-no for me
Spray-on postive resist (Positiv 20) in US? gmikol Parts 6 10th November 2006 11:34 AM
Couldn't resist this is too funny corryn00 The Lounge 0 31st January 2005 04:16 AM
Coldn't resist: feedback from 4th order lowpass !! phase_accurate Class D 23 13th December 2004 04:01 PM
Etching onto positive photo-resist board PaulHilgeman Parts 5 26th September 2003 06:17 PM
Page generated in 0.08362 seconds (71.40% PHP - 28.60% MySQL) with 10 queries
