| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 |
I normally hacksaw it outside - the dust isn't really a problem then.
#32 | |
No wonder you had so much heat... --Greg |
#33 |
I've been thinking about this:
http://www.harborfreight.com/cpi/cta...emnumber=93211 It comes with a continuous rim diamond blade, which might not be a bad choice. I understand there are carbide tooth blades out there too for this size. I just haven't been willing to spend the money to try it out. --Greg |
#34 |
Jeez, folks....
Most rotary blades will have a cutting speed thats too high - the laminate can get burnt. A guillotine is the preferred method, without specialized eqpt. Otherwise - use Pinkmouse's method - clean up with a file or a sanding block. |
#35 |
I used the Stanley knife method, sharpened with the side of a cut-off wheel on both sides of a 4 layer PCB. Scored the 4 layer PCB on both sides and then used a block of wood to assist in a clean break. Cleaned the edge with the cut-off wheel. It was fairly fast, 10 minutes of careful work and yielded an excellent result. Thanks AuroraB.
#36 |
I use a 1mm carbide router bit with a Proxxon grinder and a modified Proxxon drill press. The grinder and bit face down on a base that I built. I added a movable fence to help guide the board through. The nice thing about this setup is that it doesn't matter what angle the fence and board is to the bit. I always get a straight and very clean cut.
When I not cutting boards, I use it as a regular drill press for drilling the boards. David.
DB |
#37 |
Tile wet saw. You can get small cheap ones where the blade runs through a water bath, no pump, and eliminates dust. A continuous rim tile blade may not be optimum but a segmented blade or turbo style blade should do well. You can get cheap Chinese variants of these blades that would be fine for circuit board. Look for a blade that states it's for concrete or granite. You can get them cheaply in the 3 to 4 inch size that fits one fo these cheap $50 saws.
#38 |
Now THAT makes sense.
#39 |
Milling with a fish tail bit is the least stressful way if the board is populated. If you cut using a wet system the boards would be best dried in an oven if PTH or multilayer, especuially if using lead free solder, I cant remember the temp and time, but use to do it regular many years ago to help avoid outgassing.
| The easiest way to reduce box volume | DAMIC | Multi-Way | 7 | 17th July 2009 06:51 AM |
| Easiest to build class-A? | Doug Kim | Solid State | 17 | 26th September 2008 11:16 PM |
| Easiest way to correct this dip? | JCoffey | Multi-Way | 12 | 11th June 2007 01:52 PM |
| cleanest/ easiest EQ | rick57 | Digital Source | 15 | 1st July 2005 04:52 PM |
| Bets and easiest type of amp? | T_Lav | Solid State | 4 | 13th September 2001 05:35 AM |
| Page generated in 2.64607 seconds (-89.32% PHP - 189.32% MySQL) with 10 queries |
