| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
should have added from the same maker ! The better sounding resistors tend to be those with better specs wether they are carbon or metal film construction.
#22 | |
I find both NiCr Susumu thin film ($0.40) and Vishay bulk metal foil ($20) SMT resistors are weakly attracted and stick to rare earth magnets. If I can find ones that I don't need, I'll cut the ends off to isolate where the attraction is. |
#23 |
TaN film SMT also attracted to rare earth. And $20.40 later, find that it is indeed as Sy indicated--the ends of the Susumu/Vishay are attracted.
Of TH resistors, "superb PRP 9372 audio grade metal films from Precision Resistive Products" very attracted even the body. Of the resistors I tested, only Holco resistors are standoff-ish. (Least now I know which resistor will make my audio arc welder sound best :P . . . jk) |
#24 | |
Quite a few components have magnetic leads as well, not just the body. Capacitors, glass body diodes and resistors. |
#25 |
#26 |
I've never seen magnetism used by pick and place.
Steel/iron is much cheaper than copper |
#27 |
Pick and place use vacuum, never magnetism, just to second Davids comment.
As these components are going to be in circuits with ac, how is the megnetism gonna effect ANYTHING! Just curious. |
#28 |
Long ago I was developing broadcast tv monitors. We had a horrible kink in the display that was eventually traced to a TI 741 in the psu with a ferrous lead frame picking up the field from the scan coil. Changing to another vendor solved the problem.
Iron leads can make good low frequency antennas |
#29 |
Yes in a colour monitor with HT, line transformer maybe, but these days with our awareness of emc etc, I have never known an engineer these days to be concerned with some slight magnetism in components, apart from transformers and inductors, and when designing a PCB or an assembly you keep sensitive circuitry away from such things.
#30 |
Davidsrsb, was around the time when TI came up with the EMC coating for thier chips to help combat what was a major EMC faux pas.
| metal film resistors or carbon? | leitmo | Tubes / Valves | 2 | 28th June 2008 11:14 AM |
| riken resistors: carbon comp or carbon film? | jarthel | Parts | 0 | 20th October 2006 02:00 AM |
| Res Survey:....... Carbon film ...or... Metal Film ...............?? | nina | Chip Amps | 13 | 14th April 2005 01:46 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 01:22 AM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 02:57 PM |
| Page generated in 0.09959 seconds (78.20% PHP - 21.80% MySQL) with 11 queries |
