| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
I've found that wall warts are without doubt the weak link in many applications ....build a descrete unit you will not be sorry.
#12 |
Hi.
If your voltage is 225, then try and find a 240V primary 15V transformer, this will output 14V when driven from 225V. Alternatively get a transformer bigger than you need with 2 * 15V windings, and use one in series with the primary to reduce the voltage. Just a couple of ideas. Chris |
#13 | |
You will only have the enamell coating of the copper wire providing insulation from mains to your secondary, as the copper wires from both secondaries will be in physical contact. I wouldn't recommend this, ever. |
#14 |
good point.
most modern trafos don't have good secondary-secondary insulation. Chris |
#15 |
Don't forget about the regulation factor - often the secondary voltage will be as much as 25% higher than the stated voltage.
Scondary voltages are usually quoted fully loaded - so for your application I would go for a 12 volt AC transformer - this will certainly work OK and not cause excessive heat dissipation in the FX units internal regulators.
John Audio |
#16 |
Thanks all for the replies!
I found an oversized (80VA) C-core transformer at work which has 4 or 5 different windings. So I combined two of them (12v and 2v) to produce 14V, I did turn out a bit high so I still used the antiparallel diode approach to get to 14,3V AC. I opened it up (because of a problem I was not told about, aint eBay great?) it has a 7809 and 7909 regulator. So I might use 15v or so, because as it is now 19.6v is a bit to little to get to 2x9V (I think you would need at least 15,5V AC). The regs only have about 0.8v overhead (and they need 2v?). Regards, Jarno.
Oemptempa petoempetapap |
#17 |
Hi Jarno,
your guess (calculation) is correct. To get regulated 18Vdc (+-9Vdc) you need about 18Vac to allow for losses, ripple, reg overhead and low volts from mains. You might need heatsinks for the IC regs depending on current draw. I suspect the 14Vac recommendation was to ensure the manufacturer got replacement sales and he was using the high regulation to get sufficient overhead to drive the regs and when current draw increased voltage fell to reduce power dissipation.
regards Andrew T. |
#18 | |
Jan Didden
/Another new issue: Linear Audio Volume 3! |
| One transformer with 4 secondaries or two transformers with dual secondaries | Baka | Chip Amps | 5 | 28th November 2008 06:39 AM |
| Unused secondaries | pilli | Parts | 8 | 7th October 2007 10:14 AM |
| Aleph L PSU and 50V secondaries | Stabist | Pass Labs | 20 | 28th June 2005 09:59 AM |
| R vs. RC on secondaries | kasra | Tubes / Valves | 7 | 29th March 2005 04:04 PM |
| ? on secondaries of a tranny | JazzzSpazzz | Parts | 13 | 21st April 2004 05:58 AM |
| Page generated in 0.10203 seconds (75.86% PHP - 24.14% MySQL) with 10 queries |
