Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd September 2002, 05:06 PM   #11
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Slightly off topic but...
I just bought 2 500VA transformers (TOTAL overkill...but useful for future) and a 120VA transformer, 10 Audio Grade 6800uF caps and lots of other PSU goodies...for the bargain price of...
£140!!!!!
Thanks Maplins! They make a killing out of me! If I lived in USA I'm sure I'd pay alot less!
Never mind!
Gaz
Old 22nd September 2002, 05:09 PM   #12
PMA is offline PMA  Europe
PMA's Avatar
Steve,
of course. Just didn't want to confuse :-))
Pavel
Old 22nd September 2002, 05:26 PM   #13
Steve Eddy's Avatar
Originally posted by PMA
Steve,
Pavel
Oh I know. I wasn't intending to take away anything from your post. I replied because your drawing helped illustrate more clearly something I'd said previously. Thanks!
se
Old 22nd September 2002, 05:50 PM   #14
Well I must admit I'm lost for words, I only discovered this site this morning, but the amount of replies is incredible
Thanks everyone
And now to build this thing....
Old 22nd September 2002, 05:56 PM   #15
www.audiohobby.com
If you have a (two secondaries) transformer with unidentified leads, is it possible to determine the dotted leads with an AC signal generator and a scope?
Old 22nd September 2002, 06:53 PM   #16
Steve Eddy's Avatar
If by unidentified leads you mean not identified in terms of relative polarity, then yes.
Just feed a sinusoid into the primary and connect the probe of one channel across the primary. It doesn't matter which primary lead you attach the probe to or which you attach the ground to. It's AC so polarity is relative. Whichever lead you attach the probe to, designate that lead as the reference. In other words, that will be the primary lead that will be assigned a "dot."
Then connect the other channel to the seconary (or one of the secondaries if the transformer has multiple secondaries). Again, it doesn't matter which lead you attach the probe to or you attach the ground to.
Using the same timebase for each channel, check the phase of the two signals. If they're in phase, then the secondary lead that the probe is attached to is of the same polarity as the primary lead that the other probe is attached to and this lead will be the "dot" lead for the secondary.
If they're out of phase, then the lead that the ground is attached to will be the "dot" lead for the secondary.
Repeat as necessary for any other secondary windings.
se
Old 22nd September 2002, 07:38 PM   #17
www.audiohobby.com
Terrific explanation! Thank you, Steve.
Old 22nd September 2002, 08:22 PM   #18
paulb is offline paulb  Canada
An easier way that doesn't require a scope, just a voltmeter:
Apply a signal to the primary; you should be able to read voltage from both secondaries. Then just connect the secondaries in series and measure across them; if you've connected them correctly ('dot' to 'non-dot') you'll get twice the voltage. If not, you'll get close to 0.
Old 22nd September 2002, 09:31 PM   #19
Steve Eddy's Avatar
Yes, that will work as well. I gave the answer I did because the original poster asked specifically how to do it with a generator and a 'scope.
se
Newbe question about power chips Musiclear Solid State 2 17th November 2006 06:51 PM
ANOTHER newbe question!!! Dannyball Multi-Way 11 27th May 2004 03:13 PM
simple transformer question owel Parts 3 12th March 2004 06:41 PM
Newbe and first question josefr Digital Source 1 28th March 2003 09:57 PM
Simple Aleph 2 transformer question BrianGT Pass Labs 14 7th April 2002 10:27 PM
Copyright ©1999-2013 diyAudio
