Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th August 2005, 12:58 PM   #1
Calebay is offline Calebay  Denmark
Question Black = negative Cap
Hello
i have 4 older caps 22000uf 80V from a sony ES power amp
but i have no idear what is + and -
Black= negative or is it the other way araund? see pic if that help
Tnx
Old 9th August 2005, 01:01 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Do you have any text printed on the can?
/Per-Anders (my first name) or P-A as my friends call me
Old 9th August 2005, 01:10 PM   #3
this is all it says
Old 9th August 2005, 01:38 PM   #4
peranders's Avatar
Take a DVM and measure the resistance between the terminals and case. Normal negative is more or less connected to case.
Old 9th August 2005, 02:27 PM   #5
im not able to measure anything infinity resistance
anything else i can try before i connect my 450VA trafos?
Old 9th August 2005, 02:42 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Try it with a 12V trafo through a resistor of say 100 ohms first to see if the caps are connected correctly. If not, you will see a very large current resulting in low voltage at the caps. Can you measure voltage? And oh, btw, you didn't mention the rectifiers, but you have those too?
Jan Didden.
Old 9th August 2005, 03:26 PM   #7
okay ill try that first yes i have a multi meter i did try to measure the but it seems like the non of the terminals have any connection to the case at all..
don't worry i have rectifiers in there as well i have build an amp before
Old 9th August 2005, 04:06 PM   #8
okay i did this test using a 9v batt instead i connected my multimeter in serie whit the batt. to measure the current
when i connect it to the cap the same this happens no matter if its + or - it draw a large amount of current the first few seconds, then drop to zero. seems normal..
i also try to measure the voltage over the cap after its been charged. its drop for 9 volt slowly. the same speed + and -
Old 9th August 2005, 04:11 PM   #9
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Maybe this helps:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 9th August 2005, 04:13 PM   #10
Netlist is offline Netlist  Belgium
Netlist's Avatar
Somewhere on the board there's a clever post how to measure polarity with a scope, looking at dropping waveforms. I can't however remember who posted it, when and where.
/Hugo
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 09:05 PM
Negative Sziklai timH Solid State 17 30th July 2007 11:13 PM
H. S. Black: inventing the negative feedback amplifier (1977) Bricolo Parts 6 13th June 2006 03:41 PM
Negative feedback? Solid Snake Solid State 33 14th March 2003 02:29 PM
Page generated in 0.11144 seconds (80.38% PHP - 19.62% MySQL) with 11 queries
