| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 | |
Yeah well I think 9V is a little too low. Try, if necessary, with your big transformer but with a series resistor. I would also vote for the black terminal being neg pole, btw. It seems pretty standard. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#12 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 |
That's the one, Peter. Seems you don't need the search engine, you know the threads from memory.
/Hugo |
#14 |
Actualy I remebered that Moamps used the name Fred in this thread, and this is how I did my search.
#15 |
Leaves us with the question: Is the inner or outer foil + or - ?
Or should I re-read the thread? /Hugo |
#16 |
yep also got a cap thats says negative = black
i did the test agin this time using 2 9v batt in serie ´Better the black was negative i also tried using the scope test. but no luck whit that one don't know what i did wrong.. tnx for the help |
| Negative Feedback | AmpBuilder225 | Tubes / Valves | 7 | 20th February 2009 08:05 PM |
| Negative Sziklai | timH | Solid State | 17 | 30th July 2007 10:13 PM |
| H. S. Black: inventing the negative feedback amplifier (1977) | Bricolo | Parts | 6 | 13th June 2006 02:41 PM |
| Negative feedback? | Solid Snake | Solid State | 33 | 14th March 2003 01:29 PM |
| Page generated in 0.08612 seconds (73.48% PHP - 26.52% MySQL) with 11 queries |
