Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Did I hook this up right?
Old 6th August 2005, 01:01 AM   #1
HolyGhostFire20 is offline HolyGhostFire20  United States
Account Disabled
Default Did I hook this up right?
Right now I am in kind of a dilemia about hooking up this battery power supply correctly. As you can see in the picture the batteries are connected in series and parallel so 12v and 24v are outputed. Will noise from the AC line come in through the batteries if I keep the ground connected all the time from the charger to the batteries ? Should I use a different switch than the DPDT switch? Just look at the picture and give me the best options in connecting two 12v batteries to output 24v and 12v while having a switch to connect a 12v charger. Thanks a bunch for your help. I appeciate it.
Old 6th August 2005, 04:20 AM   #2
AudioWizard is offline AudioWizard  France
Well, according to your drawing, the left battery is shorted. So this ain't going to work.
Old 6th August 2005, 05:05 AM   #3
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
Try something like this. The relay needs to be 12v, 4pdt. When you plug in the charger, it will power the relay, which will connect the batteries in parallel and charge them. When the charger/relay is off, the batteries are connected in series for 24v. I think the best way to get 12v from that is to use a voltage regulator. When you use just one battery to get 12v to power relays, it will get discharged more than the other one, which will not be good. And you cannot have the batteries connected in parallel and series at the same time.
Old 6th August 2005, 04:01 PM   #4
Account Disabled
Hey xplod1236
I like your idea of using a 4pdt power relay to charge the batteries in parallel and still run them in series. My other question is if it would be alright to hook up a 5v and 12v regulator to a 24v line. I was planning on using the lm7805 for the 5v regulator and a generic regulator for the 12v line since it is only powering the output and delay relays. The 5v line is more important since it powers the tripath processor chip. Thanks again for all your time.
Old 6th August 2005, 04:39 PM   #5
Account Disabled
I forgot to add that the 12v batteries together will output 10Ah of current. Will this matter in the voltage regulators I can choose? Thanks again.
Old 6th August 2005, 04:53 PM   #6
xplod1236's Avatar
Yes.
In series the batteries will only put out 5Ah. Which regulators you can use only depends on how much current you need out of them.
Just a suggestion; why not use 24v relays? That way you won't be wasting power in the 12v regulator.
Old 6th August 2005, 05:52 PM   #7
Account Disabled
How do I use 24v relays to bring the voltage down to 12v? I am completely new when it comes to relays. Could you show me an example? Thanks again.
Old 6th August 2005, 10:15 PM   #8
xplod1236's Avatar
What I meant was instead of using a 12v regulator and 12v relays, use relays that run off 24v.
Did I hook this up right?Hide this!Advertise here!
Hook up pot help needed DeanP Chip Amps 1 12th June 2007 02:11 PM
How to hook up Speakons? jonz Multi-Way 5 21st May 2004 03:25 AM
Hook-up Wire? mwh-eng Tubes / Valves 6 4th March 2004 08:30 AM
CD Recorder Hook-up jschiltz Digital Source 1 16th February 2004 10:48 PM
i need help w/ my car stereo hook up.. albooogie Multi-Way 1 27th January 2004 01:23 PM
Copyright ©1999-2017 diyAudio
