Encapsulated power Supply Toroids - Are they better? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st August 2005, 08:39 PM   #11
wytco0 is offline wytco0  United Kingdom
tekman, thanks for that, do you put the thick plate under the case or inside it under the transformer? I think you mean under the case. I had not thougght of that idea but it sounds good.
Old 2nd August 2005, 06:24 AM   #12
tekman is offline tekman  Germany
Hi wytco=,
I had good results to but the thick metal sheet under the thin metal,
so it is most far away from the toroid.
The "sandwich" would be stucked like this:
toroid
rubber
thin metall
thick metall
Ok, I guess this shows the idea I have in mind: The force is "dirtributed" to a larger area, so the thin metall is "reliefed".
Sorry for my lack of words, I am not a native speaker ;-))
Well, in my projects this always worked fine. So, just give it a tray - good luck for your project to become a success!
hth,
Andreas
FS: Large Power Toroids. K-amps Swap Meet 15 24th April 2010 01:12 AM
Toroids, Capacitors, Power Supply PCB FS swin1 Swap Meet 0 28th October 2008 01:20 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 07:30 PM
UK: 2 x Encapsulated Toroids 25-0-25v 160VA ShinOBIWAN Swap Meet 6 14th February 2006 09:56 AM
High power toroids source Lupulroz Swap Meet 10 30th July 2003 02:38 PM
Copyright 1999-2017 diyAudio
