Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
cable hack to use klipsch promedia 5.1 with stereo?
Old 14th July 2005, 07:23 PM   #1
whammoed is offline whammoed  United States
Default cable hack to use klipsch promedia 5.1 with stereo?
I would like to make a cable to hook up a regular stereo output to klipsch 5.1 promedia speakers which require 6 channels, the two for the sub and center should be mono. It seems like when I combine the right and left channels for mono, that all channels would be mono. I have attached a crude diagram to show what I mean. Is there a way to keep the right and left signals from combining on the other four channels?
Old 14th July 2005, 11:01 PM   #2
I'll try that file again:
Old 15th July 2005, 01:22 AM   #3
hvymtl427 is offline hvymtl427  United States
Default splitters @ radio shack
ok, does it have the smaller stereo plugs to plug into the back of the computer? (ie. same size as mini headphone jacks found on walkmans)
if so go to radio shack - get the adapter that allows for two mini jacks to plug into one jack - that will get you the left & right front and rear channels. (what I did for my old 4.1 promedia set)
Buy two additional splitters (two mini jacks into one) and plug them into the first splitter. This will allow for 4 plug ins - one for right frnt/rear, one for left front/rear, one for center and one for sub. If I remember, plugging in a mono plug into stereo will do for the sub. (Tho it may only pick up one channel of the stereo...)
to diagram it
stereo
______________| <- splitter 1
______________/\
____splitter 2->| | <-splitter 3
____________ /\ /\
____________a bc d
a: left front/rear
b: right front/rear
c: center channel
d: sub
best of luck
garage sale - ing my way to some audio bliss...
Old 15th July 2005, 03:06 PM   #4
Yeah thats the thing, the sub and center is one stereo type 3.5 mm plug that -should- have 2 mono signals as opposed to stereo. I found some more info on the web about mixing signals and I don't think its going to be possible with the cables. I suppose I could just use splitters like you suggested and drive the sub from the left channel and the center from the right. I'm not sure that would sound ok though. Any other suggestions? I wish they still made the 4.1. Maybe ebay...
cable hack to use klipsch promedia 5.1 with stereo?Hide this!Advertise here!
help with dead Klipsch ProMedia 2.1 grjr Solid State 11 23rd February 2010 02:40 PM
Need help with klipsch promedia 2.1 mrfix90 Solid State 3 8th April 2009 03:19 AM
Need help with Klipsch 2.1 Promedia Please mrfix90 Subwoofers 0 31st March 2009 03:45 AM
Klipsch Promedia BASH amplifier rkc7 Class D 7 12th December 2004 12:50 AM
klipsch promedia replacement smak Multi-Way 0 7th September 2003 05:37 PM
Copyright ©1999-2017 diyAudio
