Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th July 2005, 10:39 AM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default External screen heats up tranformer rapidly
Last night I added an electrostatic screen (3M copper tape) on the outside of my filament transformers. And soldered the outside screen to the internal electrostatic screen that runs between primary and secondary. To my suprise the transformer got warm real fast????
I don't understand why that would happen. So I removed the extrernal screen and voila..did not get warm anymore. I realize now after typing this that I should have just disconnected the external from the internal screen first...
Anyway..anyone have an explanation?
Old 13th July 2005, 11:02 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
If you connected the two screens together, it sounds to me like you're making a shorted turn
/U.
Old 13th July 2005, 11:03 AM   #3
heater is offline heater  Finland
Seems to me that if you wrap copper tape around a transformer you have effectively added another scondary winding of one turn.
So now your primary is pushing current around this new short circuited secondary thus getting loaded and hot.
Wrap one turn of tape but keep the ends insulated from each other where they overlap so you don't have a current loop and you would be OK.
For me the past is not over yet.
Old 13th July 2005, 11:26 AM   #4
Yes..I think that would be the solution. You are right ofcourse..it's another secondary but shorted now..
Old 13th July 2005, 12:58 PM   #5
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Did you put it around the WINDINGS, or around the whole TRANSFORMER? Big difference
Flux goes one way up through the center limb (which the windings are wrapped around), then goes back down the two outside pieces (or just one in a C core). 2 - 1 - 1 = 0 so a "shorted turn" around the outside of it all will only squash leakage, while the majority of the field happily circulates inside the core where it belongs.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 13th July 2005, 01:08 PM   #6
I had it on the windings
like in the pic
Old 13th July 2005, 06:02 PM   #7
Sch3mat1c's Avatar
Yeah, that'll pull a few tens of amperes! Wrap it in the same position but around the outside of the whole transformer and it'll be good.
Tim
Old 13th July 2005, 08:06 PM   #8
mzzj is offline mzzj  Finland
like in the pic
Classical way to get couple of hudreds amps from toroid is to fix it to chassis with trough-bolt that is in contact with metal chassis from both ends
Toasted PW tranformer? whitelabrat Tubes / Valves 16 2nd January 2008 01:42 PM
1st cap heats up... JojoD818 Tubes / Valves 11 21st September 2006 05:33 PM
Step down tranformer jkeny Everything Else 2 18th October 2005 12:14 AM
kenwood excelon amp over heats to 203F mattsoft Car Audio 4 21st September 2005 12:54 PM
Tranformer question CPX Parts 3 7th February 2005 07:44 PM
Page generated in 0.10077 seconds (73.72% PHP - 26.28% MySQL) with 11 queries
