Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th July 2005, 06:35 PM   #1
choppa is offline choppa  United Kingdom
Default Urei Little Dipper and notch filters
I'm looking for a little dipper or high quality shelving/notch filter to attenuate room resonances. Does anyone have a ciruit diagram for a Urei 565 "Little dipper" or similar high quality notch filter. I could possibly trade diagrams of from an Amek BCII if these are of use. Many thanks.
Old 14th July 2005, 11:37 PM   #2
Brion55 is offline Brion55  United States
Send a message via Yahoo to Brion55
Here is a schematic for a parametric EQ which can give you -15dB notches with 12dB/octave (2 pole) slopes. The bandwidth control can be adjusted from a wide 3.3 octaves to a very narrow .05 octave. Only one filter (band) is shown, but you can make as many as needed. The supply should be a clean, regulated bipolar 15 volts. If you need help with the supply, I can find you a drawing.
How do I put the smoke back in this thing?
Active notch filters neutron7 Full Range 2 19th November 2006 11:51 AM
Multiple notch filters? Mikael Abdellah Full Range 2 25th August 2006 05:09 PM
Help on series notch filters. bowdown Multi-Way 1 9th March 2005 05:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
