| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Not sure what to call this, but it's something that I need just for my desk/computer audio setup. I want to be able to send signal from both the headphones out of my computer, and my CD player to one 'channel' of a NAD 7120 Receiver. I want to be able to have level controll on both, so in reality 4 channels of audio. What I see me needing to do is put diodes on all four signal lines and then pots on them. Is this the right way to go about doing this? I basically want to make a mini-mixer type idea, but don't need all the features such as eq . I'm not sure what this is called or I would have searched. If anyone has done this or knows how to, or knows what I am looking for, I would appreciate it. If you have a schematic or pcb layout, even better.
Thank You, Cam |
#2 |
Would something like this work? http://www.jensen-transformers.com/as/as014.pdf
also, i now realize I posted this in the wrong area. Can a mod move it to Everything Else? |
#3 |
Banned
why not just buy a 1/8th jack to rca adapter ?
PLug one end into your line out / speaker out on your commputer and then the other into cd on your nad.. |
#4 |
Because that's what i'm doing with the computer, and I want to be able to listen to a cd and my computer at the same time.
#5 | |
Banned
Why .. what is the point of that ? Id just buy another amp.. i can't see your amp controling 2 inputs at the same time.. |
#6 |
or just play the cd on the computer
#7 | ||
#8 | |
Banned
And you can't run 2 sources on a amp.. well you can with a pair of y adapters but this all sounds so retarted and waste of time.. why are you doing this again.. who on earth listens to 2 audio sources at the same time ? |
#9 |
I would like to.
Ever been to a concert? |
#10 |
It's not that stupid listening to two audio sources, I sometimes used to play games with all sound effects, whilst listening to some appropriate CD music instead of the poor MIDI In-Game music...
You could try it a with two simple stereo potentiometers, and then mix both channels into one... No diodes required. From there on, you can make it as complicated as you want The easy-to-buy solution: A small (studio/DJ) mix panel? Cheers! Bouke
More Power Igor! More Power! |
| NADS - what you get for your free time | 454Casull | Multi-Way | 18 | 28th April 2009 01:06 PM |
| I have things | sauuuuuce | Swap Meet | 0 | 13th October 2006 02:40 AM |
| Things important to be said..helped by Mr. John Mateus to express things. | destroyer X | Solid State | 22 | 31st July 2006 07:21 PM |
| Inserting tubes into Express PCB | alexmoose | Tubes / Valves | 9 | 19th June 2006 02:15 AM |
| Inserting Quotes. | mrfeedback | Forum Problems | 2 | 1st April 2003 08:16 PM |
| Page generated in 0.11205 seconds (77.05% PHP - 22.95% MySQL) with 11 queries |
