Inserting things into my nads... - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th July 2005, 04:02 PM   #11
xplod1236's Avatar
Send a message via AIM to xplod1236
CD drive is usually being used.
rip the cd, and play it from the hard drive.
Old 6th July 2005, 02:56 AM   #12
Brion55 is offline Brion55  United States
Send a message via Yahoo to Brion55
Would you be going into the auxillary input on the stereo amplifier?
How do I put the smoke back in this thing?
Old 6th July 2005, 03:14 AM   #13
imix500 is offline imix500  United States
imix500's Avatar
Maybe it's been mentioned, but "y"ing two sources together is not a good idea. There must be a way of at least partly isolating them from each other. Output devices don't take to kindly to being slammed into by another source. There was a great article posted by Masque Sound about that a while back but I can't seem to find it...
Old 6th July 2005, 03:17 AM   #14
ctardi is offline ctardi  Canada
Send a message via MSN to ctardi Send a message via Yahoo to ctardi
NO! I can't play the source from the computer, okay?
I would be going into either tape, aux or phono, depending on the gain I need.
Old 6th July 2005, 03:18 AM   #15
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
just build a device with a dpdt for each channel and switch sources by applying power to the relays?
Diodes like that on the input stage would be bad with a ~.6V bias you would only get the peaks of the signal or more likely no signal.....
Old 6th July 2005, 03:32 AM   #16
I'm not trying to switch sources, I'm trying to listen to two at the same time, and be able to controll the volume. Please read before you talk.
Old 6th July 2005, 04:12 AM   #17
This should do the trick. The 10K resistors pad the headphone level and isolate the two sources. The dual-gang pots will allow you to adjust each source. The headphone signal levels are plenty high enough to drive the aux inputs even after 1/2 voltage division with the R's and Pot's.
I've used this circuit many times to feed a tape or CD headphone output to an audio amplifier. Keep the volume on the headphone source fairly low to prevent distortion.
Happy mixing!
Old 6th July 2005, 04:13 AM   #18
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
This may be the thread:
Combining 2 channels to one
ctardi, best to be positive, after all , you are asking for a favor...
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Old 6th July 2005, 04:41 AM   #19
After a long day of dealing with some really bratty kids, it's hard to be positive.
Thank you to those who have given advice, I think I will go with what Brion suggested...
NADS - what you get for your free time 454Casull Multi-Way 18 28th April 2009 01:06 PM
I have things sauuuuuce Swap Meet 0 13th October 2006 02:40 AM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
Inserting tubes into Express PCB alexmoose Tubes / Valves 9 19th June 2006 02:15 AM
Inserting Quotes. mrfeedback Forum Problems 2 1st April 2003 08:16 PM
Copyright ©1999-2017 diyAudio
