Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best Relays for signal path
Old 10th September 2002, 09:02 PM   #1
jgwinner is offline jgwinner  United States
Question Best Relays for signal path
I've been browsing Mouser looking for relays for my soft start power supply and for my speaker protection circuit.
Does anyone have any specific suggestions for a good, audiophile quality relay?
There's so much discussion on resistors, capacitors, etc that are in the signal path, but here's something that's smack dab in the signal path that we feed DC or (gasp) AC into I'm surprised no one has produced some $548 version of a relay
I like the hermetically sealed varieties but they are expensive.
Does anyone have brand suggestions?
P.S. Yes, I did do a search, didn't find much.
== John ==
Old 10th September 2002, 09:05 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default relays
Should have searched some more: Pickering type 100, 101. www.pickering.co.uk. About $2 in small quantities
Jan Didden
Old 10th September 2002, 09:27 PM   #3
Jan:
I meant I searched the forum for mention of specific Relay brands. I've found plenty of relays.
I checked out the pickering site, and under 'high power' they go to 40w; the type 100, 101 isn't even that high.
Maybe I'm not being clear . I want something with relay contacts rated for:
1) 1500w power supply soft start
2) Speaker protection. At least 100w, preferably 200w.
What I'd like to know is has anyone tested high power relays for THD, S/N, etc?
(edited to replace janneman with "Jan")
== John ==
Old 10th September 2002, 09:33 PM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Best Relays for signal path Send a message via AIM to Peter Daniel
Mercury wetted relays: are they any good for signal?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 10th September 2002, 10:07 PM   #5
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
just like teh ones your getting PETER : O )
Old 11th September 2002, 05:31 AM   #6
BrianL is offline BrianL  United States
Default Pickering
Jan,
No one in their right mind would use Pickering. Expensive,
long delivery time, poor quality and reliability. If you're
looking for reed relays, look to Coto. For non-reed
small signal, I'd give guarded endorsement to Aromat
TX-S (if hand tested/selected) or SX series.
the voice of experience, with 10's or 100's of thousands
used...
bel
Old 11th September 2002, 06:34 AM   #7
jan.didden's Avatar
Default Best relays
jgwinner:
Sorry, I goofed. I just reacted on your heading "relays for signal path".
For speaker protection I use with no problems a specially developed relay by amplimo (the people that develop the toroid OPT's for Menno van der Veen). The relay uses a primary wolfram (I think in English it is Tungsten?) 100A contact, bridged with a lower current gold contact.
BrianL:
I have good experience with pickering, but will check out Coto nevertheless.
Jan Didden
Old 11th September 2002, 06:49 AM   #8
yeti is offline yeti  Germany
Default Relays
Try to get some of those relays used by the telephone companys in their distributon racks.
They can stand some Amperes and are extremely reliable, also the contacts don't tend to frie together, an important issue in a protection circuit.
Usually they use 24 V solenoids.
Regards;
Arne
Old 14th September 2002, 08:57 AM   #9
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Yes they are the only one without contact bounces and can work down to zero ampere but unfortuneatly they contain mercury. Since a couple of years they are forbibben to sell (here in Europe) except for replacement parts. But this type is only suitable for small loads
But since we talk speaker signals check relays with hard silver (AgNi) alloy contacts. Avoid silver cadmium (AgCdO). The Swiss brand ELESTA is one of the best but also not the cheapest.
Contacts with wolfram (tungsten) is only suitable for loads with high inrush currents such as lamps. I gather that the speaker relay always switches on (and very seldom off) with no or litte current, go gor hard silver instead.
NIAS has many good relays. The SD type is excellent for small signals and for large signals they have similar types
http://ctlgserv.mew.co.jp:80/ctlg/ac...cs=dynaweb1.wv
http://ctlgserv.mew.co.jp/ctlg/acg/e...et=dynaweb1.wv
Check the SF type. They have a similar type which don't is a safety relay but I can't find the name. I have this relay in a subwoofer.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 53 pcb's in interest so far.
Old 14th September 2002, 10:02 AM   #10
roddyama is offline roddyama  United States
diyAudio Moderator Emeritus
roddyama's Avatar
Peter,
When I was putting together Data Acquisition and Control Systems, mercury wetted relays were the only relay we would use in a control feedback circuits, and then only in rare situations. I don't know what it might do to the sound, but they were 16bit analog signals that we were switching, so signal integrity was crucial. These were low level signals (mA) that we were switching.
I have attached a pic from the 2000 Allied Electronics cat. These are similar to the kind we would use for emergency cutoff of high current circuits. Again, I don’t know how these relays will sound, but if I were to use a relay on my DC buss, it would be these or similar.
Rodd Yamas***a
Best Relays for signal pathHide this!Advertise here!
What is the signal path -- the red line? oldeurope Tubes / Valves 84 31st March 2009 02:50 PM
Relays in digital signal path Prune Digital Source 23 2nd July 2004 07:08 PM
Capless signal path? Solid Snake Solid State 40 8th December 2003 04:51 PM
Copyright ©1999-2017 diyAudio
