Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th June 2005, 07:33 PM   #1
Send a message via MSN to youyoung21147
Question Calculating a stepped attenuator resistors values...
As I plan to build a Gainclone, I'd like to put a stepped attenuator instead of a pot on it.
I already know a few things about how to cable it : it progressively shorts the output to ground after an input resistor which limits current and keeps input impedance high enough.
I will use two rotary switches (2poles * 6positions) in series, meaning there will always be 2 resistors in series, and allowing 36 different positions.
As I'm not so good at maths, I wondered how to calculate the resistors values, in order to get a linear acoustic attenuation.
I suppose it depends on the input impedance, and that it follows a log law, but I don't know how to use it.
How easy it is to give a smoother attenuation to a part of the attenuation range ?
If anyone could help me, I'd be glad !
Fostex F120A speaker pair for sale - 250€ only !
Old 8th June 2005, 09:23 PM   #2
moamps is offline moamps  Croatia
The picture below shows one possibility.
On the audioXpress site http://www.audioxpress.com/magsdirx/...enda/index.htm you can find a simple Excel spreadsheet (att.xls) for calculating attenuator values. There is also an article that goes with the spreadsheet, which was published in this month's issue of aX.
Milan
Old 11th June 2005, 04:58 PM   #3
Send a message via AIM to Klang Projekt Send a message via MSN to Klang Projekt Send a message via Yahoo to Klang Projekt
hello
other solution
what's my passive pre amp
the switcher is from elma 2x24
the sound is very clear
I can send you a photo where you can see the resistor range (for a 10kOhm stepped attenuator)
regards
Klang Projekt
Old 13th June 2005, 07:07 AM   #4
Nice realization ! Your preamp seems really well-built and shielded !
This is the stepped attenuator solution I wanted to use, variable steps of resistors that shorts input to ground.
I made some calculations with formulas found on the Net but, as I cannot obtain a 24 or 36 positions switch, I won't be able to use a stepped attenuator in my project.
The resistance range goes from 20K to 6R so it's impossible to cover the whole range using 2 switches with resistors in series as I thought it was possible before calculating the values.
It means I need at least 3 switches which is really not practical !
I'll put an ALPS inside, I suppose it's a good pot too for my first amp project
Thanks for your replies !
Resistors for Stepped Attenuator stl Tubes / Valves 27 18th February 2009 05:07 PM
Calculating resistor values pk386 Solid State 4 10th April 2005 02:57 PM
Carbon film vs metal film resistors in a stepped attenuator? G Tubes / Valves 17 22nd August 2004 12:22 AM
Resistor values of stepped attenuator for BoSoZ stappvargen Pass Labs 1 21st February 2003 12:29 PM
DIY stepped attenuator (how to compute resistor values?) jarthel Solid State 8 16th June 2002 09:54 AM
Page generated in 0.07168 seconds (76.20% PHP - 23.80% MySQL) with 11 queries
