Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th June 2005, 02:41 PM   #1
scooby300's Avatar
Send a message via AIM to scooby300 Send a message via MSN to scooby300 Send a message via Yahoo to scooby300
Talking Capacitors What Are The Best
CAPACITORS WHAT ARE THE BEST ?
HERE`S A LIST OF MAKES OF CAPACITORS THAT I`VE GOT .
CAN YOU PLEASE RATE THEN IN 1-100%
I`VE PUT SOME VALUES IN THE ONES THAT LISTEN TO IN MY SYSTEM
IF I`VE MISSED SOME OUT PLEASE FEEL FREE TO ADD TO THE LIST . OR EVEN ADD SUB-CATERGORYS (EG. BLACK GATE STD - BLACK GATE NX)
AVX =
BC Components =
BHC AEROVOX =
Black Gate = 99
dubilier =
ELNA = 80
EPCOS =
Forever =
FRANKO =
GenElect =
Hua Lien =
JAMICON = 65
JAPAN = 20
JENSEN =
LCR =
Marcon =
MULTICOMP =
nichion = 50
NIPPON CHEMI CON = 50
Nitai =
PANASONIC = 82
PHILIPS =
RDE =
Rubycon = 70
SAMHWA =
SANYO = 45
SME = 50
TEAPO = 60
Telecon =
Tlec = 70
TOWA =
TruCap =
TSM =
VISHAY =
WIMA =
You won’t know until you listen
Old 7th June 2005, 03:08 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Scooby,
There is not such a thing as best capacitor.
Every brand makes a lot of different caps designed for different application.
You could for example state that type X from brand Y will be a good fit in application Z.
You could put a top notch capacitor rated at 85°C near a heat sink of a class A amp and find out that the poor fellow only lasts a few years. It doesn't make it a bad capacitor, it just wasn't designed for that amount of heat.
/Hugo
Old 7th June 2005, 03:26 PM   #3
scooby300's Avatar
Hi Netlist
The ones with % rating i have tested in my phono preamp where there no heat at all.
The preamp came with JAMICON caps inside of it this is the results that i have found .
I just wanted to see if anybody else has done the same sort of testing . Or what they think of certain caps good or bad.
Old 11th June 2005, 03:20 PM   #4
scooby300's Avatar
Come on everbody you must like to use some type of cap rather than other ones.
Or is Black Gate caps the best their is ?????????
Old 11th June 2005, 04:02 PM   #5
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Wherever I need a small electrolytic, I use Sanyo MV-WX. A good cap at a good price
Mads K
Old 11th June 2005, 04:32 PM   #6
Send a message via AIM to Klang Projekt Send a message via MSN to Klang Projekt Send a message via Yahoo to Klang Projekt
Hello
new CAPACITORS from Mundorf
it´s a German manufactory
Mundorf
regards
Klang Projekt
Old 11th June 2005, 04:47 PM   #7
aarsoe is offline aarsoe  Denmark
As previous stated - it really depends on the application and design.
But here is what I like so far (beside the ones already mentioned)
CDE (380LX) in power supply - Nice, fast, firm and open sound.
The Russian Teflon caps (K72) 0,1uF as decoupling - Really great cap if used in the right place, One of the best caps and the price is the best part.
Clarity Caps (SA range, if space allows) - as crossover components and as output caps - Crystal clear sound with no tendency to sounding cold and hard..
Old 11th June 2005, 06:59 PM   #8
Magura is offline Magura  Denmark
Magura's Avatar
I agree with Aarsoe on the russian teflon cap part.
When it comes to PSU caps for SS amps you will find it hard to find a cap that beats the Rifa PEH169's for performance, ruggedness and lifespan.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 11th June 2005, 09:53 PM   #9
scooby300's Avatar
All these caps (Mundorf , russian teflon , Rifa) you mention are well beyond my price range . And i thought Black Gate caps where very pricey.
Old 12th June 2005, 06:07 AM   #10
Scooby
Why do you say that? The K72 caps can be found on ebay for less than a dollar a piece (If you pick the right seller). Claritycap are expensive, but still much lower than Mundorff (check diycable.com).
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Oil capacitors Praudio Swap Meet 3 7th October 2003 03:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Page generated in 0.11425 seconds (78.85% PHP - 21.15% MySQL) with 11 queries
