Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Combining 2 channels to one
Old 5th June 2005, 08:06 PM   #1
klitgt is offline klitgt  Denmark
klitgt's Avatar
Default Combining 2 channels to one
Hi
I have an active x-over with 2 channels in both high pass and low pass lines. Now I want to combine the 2 channels (left & right) in the low pass line after the L & R output buffers to feed one single poweramp that drives one single subwoofer.
As far as I know this is possible if I connect the outputs through resistors as shown in the diagram attached.
But the values of the resistors is a ??? to me.
Does anybody know which value to use?
And am I right with the principle shown in the diagram?
Thank's for inputs !
Old 5th June 2005, 10:09 PM   #2
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Try 2200 ohms.
Old 5th June 2005, 11:52 PM   #3
paulb is offline paulb  Canada
Originally posted by Bill Fitzpatrick
Try 2200 ohms.
I agree with Bill. It's the bottom resistor in your avatar.
But anything in the same range will work too.
Old 6th June 2005, 06:33 AM   #4
klitgt's Avatar
Thank's guys!
Now that I have a dialog with some knowledgeable persons, can you tell me why it is necessary with these resistors, why not just connect the leads from R and L without resistors?
Old 6th June 2005, 06:53 AM   #5
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Because if R is on a positive peak while L is on a negative peak, the mixed output shows the average, i.e. zero, but between them, they try feeding each other current. If the outputs don't use current-limited op-amps, it's a good smoke recipie. If they do, it probably won't come out right because the two amps are trying to fight each other (due to negative feedback) for control over the output. Using resistors fixes this.
The value of resistance depends on how much crosstalk/loading you want (i.e., current flowing into and out of each terminal) and the attenuation from feeding the load impedance. Ideally you'd use infinite, followed by infinite gain to counter the attenuation. That doesn't work well in practice, but where an input impedance is tolerable (well, always), a "virtual ground" mixer works well.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 6th June 2005, 07:22 AM   #6
klitgt's Avatar
I found an answer by using the inside of my head: The buffers have low output impedance and if I connect the output leads without output resistors, the output of each buffer looks into a low impedance (the other buffer). This impedance is too low, it must be the same high impedance as if the buffers look into a power amp with an impedance of typically 10-20K.
10-20K for the output resistors would be too much, as the resistors form a voltage divider together with the input impedance of the power amp.....and thus attenuatte the signal too much. So the suggested 2200 Ohms for the resistors is what I will go for, thank's again to all
Old 9th June 2005, 08:41 PM   #7
AndrewT is online now AndrewT  Scotland
connecting those two resistors to an inverting opamp is the normal way to SUM 2 inputs.
The inverting pin on an opamp is a virtual earth and the two outputs each see the resistor as a load to earth with no crosstalk.
The opamp reads each input and adds them together to be passed on to the next stage. It also cancels any stereo information. But into a sub-bass there is probably no real stereo information anyway. Modern electronic mixes could easily put different info irrespective of frequency and if the producer did this you would lose some or all of that as well.
If your next stage gave you access to the inverting input you could feed into that instead of the non inverting input.
regards Andrew T.
Old 16th June 2005, 08:47 AM   #8
klitgt's Avatar
Do you mean the way showed in the upper example (see attachment)?
Should there be a feedback loop (blue lead) with a resistor and if yes which resistor value? And what about the non-inverting input (pin3 at the opamp)?
What about the lower example. Are input resistors needed here and what about feedback from output to pin2? If needed, should a resistor be added? What value?
In my CDP the differential signals from the I/V converters go into pin 3 (positive ) and pin 2 (negative ) of the opamp that combines the signals to single ended in each channel. This has inspired med to draw the lower circuit example attached. In the CDP there is a feedback from output (pin6) to pin2 with a 2,2K resistor in parallel with a 180p cap.
Old 16th June 2005, 03:00 PM   #9
klitgt's Avatar
Andrew, now I have read your reply a couple of times and I think I have understood it better.
I found an appication note on NE5532/34 and here the non-inverting input is connected to ground if the inverting input receives the signal.
But I do not find any information about the reason for
"connecting those two resistors to an inverting opamp is the normal way to SUM 2 inputs."
Why not use the non-inverting input and connect the inverting to ground?
Again I would appreciate som guidance as to feed-back from output to input etc.
"If your next stage gave you access to the inverting input you could feed into that instead of the non inverting input."
My next stage is a poweramp with only non-inverting input (I guess if there is only one input on a poweramp it is a non-inverting).
So in conclusion I have to find an opamp and do as you suggest. But what are the benefits of your solution as compared with my first suggestion (see picture in the beginning of this thread) just connecting the two resistors to the input of the poweramp, without using any opamp?
Old 16th June 2005, 11:25 PM   #10
your top diagram is the summing amp. You can have as many inputs as you have resistors connected to the inverting input.
If feedback value =input value then gain=1. Two inputs will give a total output =2 times a single input.
By changing the ratio of feeback value to input value you can select the gain/attenuation you need.
Since your power amp is conventional you cannot use it in the summing manner and you need the summing opamp at its input.
You can connect the non-inverting input direct to ground but this gives a DC offset at the output.
Instead it is better to connect a resistor between non-inv & ground. The resistor value = // resistance of all the connections to the inverting input. In your example diagram if feedback value =2k2 then ground resistor =2k2/3 =733R. THEN 2* 1v INPUT GIVES 2V OUTPUT.
regards Andrew T.
Combining 2 channels to oneHide this!Advertise here!
Combining 2 speakers (possible?) burchill Multi-Way 4 23rd June 2008 11:00 AM
Dividing power between different speakers from single source & Combining channels Fusion-One Parts 0 10th April 2007 02:18 AM
Combining Inductors Jhovis Multi-Way 2 18th December 2003 02:54 AM
Combining channels for sub Taliesin Solid State 2 6th June 2003 04:47 PM
Copyright ©1999-2017 diyAudio
