| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi everyone
I was wondering if anyone could give me some advise on making a virtual ground power supply for a high current (2 amp) amplifier. thanks. |
#2 |
Hi codacola.
Building a grounded power supply is the way to go. There is no way to make a ground with passive components efficiently for that much current. ----- But ----- ........ I was intrigued by the idea and thought about it a little, and came up with the circuit here as one possible basic starting point. Virtual ground is the word - the circuit is literally the buffered virtual ground of the op-amp. Now, this is totally untested, but it seems good on paper and should provide stable regulation within mV's. You would want R1=R2, large C, and perhaps TIP41c and TIP42c for the Q's. But for 2 amp swings the op-amp might be a little heavily loaded. Let me know if you try something out! Good luck. |
#3 |
Did it Himself
That kind of thing does work, but the ground transistors need to be every bit as beefy as the main output transistors. So you might as well build a bridged amp as this uses just as many big transistors and will avoid the need for a high current virtual ground and also load the power supply in a nicer way and if done right also cancel some distortion.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Yeah, in this case, a virtual ground is equivalent to having a bridged amplifier (H bridge) with one channel un-driven.
As with that virtual ground circuit, it looks good, except I think a pair of driver transistors are in order, -and- more powerful output transistors. Most opamps won't hold still in that circuit unless the current gain in the output stage is high. This applies equally to any audio amplifier output stage. Have fun!
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#5 |
I actually agree with richie00boy 100%. It seems a shame to have such a stage working as hard as the output stage just to be an anchor!
| Virtual Ground ? | Bernhard | Solid State | 13 | 4th March 2009 01:57 PM |
| Battery PS: Virtual ground or single supply? | Dominique | Power Supplies | 2 | 5th May 2007 11:34 PM |
| Connecting Virtual Ground Circuits with True Ground circuits?? | Minion | Solid State | 1 | 12th February 2007 01:28 AM |
| Decoupling cap placement - virtual ground dual op amp? | Triophile | Solid State | 1 | 27th March 2006 06:30 AM |
| virtual ground...help | jsteigs | Chip Amps | 6 | 3rd February 2005 10:49 AM |
| Page generated in 0.08350 seconds (74.76% PHP - 25.24% MySQL) with 11 queries |
