Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th May 2005, 01:29 AM   #1
Default Stupid Silpad ?
Uhhh..ok this is the 1st time I've ever used this stuff and since there's no directions..do you leave the plastic/vinyl looking cover on? If so does it matter if it faces the heatsink or the IC?
THx
Old 4th May 2005, 01:58 AM   #2
EchoWars's Avatar
Never seen a sil-pad with a 'cover'. Pic? Or a link?
Generally, I'd think not, but I'm not sure what you are describing.
Old 4th May 2005, 02:16 AM   #3
The Silpad has a blue side that's not covered with a clear protective film of plastic & a black rubberey side that is covered with a clear easily removable clear protective film. It's obvious the clear protective film is meant to be removed because it's oversized and easily peels off. But the blue side is thicker and cut to the same size of the black side. I think it's suppose to remain but it can be taken off with a lttle more effort. Hope the pic helps.
Thx!
Old 4th May 2005, 02:18 AM   #4
Here is the black side with the clear protective film.
Old 4th May 2005, 03:23 AM   #5
TwoSpoons's Avatar
Why not just get the datasheet from the manufacturers website?
Old 4th May 2005, 09:03 PM   #6
Send a message via AIM to ScottRHinson
I take it the black side has adhesive on it? I've never used sil-pad that is self adhesive...so I'm just guessing. I have however used non-adhesive silpad...and it's blue on BOTH sides. (In fact it's only blue.) That blue is most likely part of the whole assembly.
Scott
Old 4th May 2005, 10:19 PM   #7
moamps is offline moamps  Croatia
http://www.anglia.com/product_guide/...ks/426_430.pdf
New and stupid. gbeard Introductions 2 28th December 2007 02:50 AM
Where am I able to get some silpad? DJ Exprice Chip Amps 7 28th May 2006 12:23 PM
WTB: 6x Silpad 2000 TO3P kasra Swap Meet 1 3rd February 2006 07:33 PM
This may be stupid but.. skyraider Digital Source 1 17th December 2004 10:39 AM
....and now for something very stupid..... bob4 Everything Else 2 23rd December 2002 04:00 PM
Page generated in 0.09021 seconds (82.07% PHP - 17.93% MySQL) with 11 queries
