Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How to isulate screws for to-220?
Old 16th April 2005, 11:36 AM   #1
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Default How to isulate screws for to-220?
Maybe a silly question, but I did the silly thing:
I used mica between to-220's and heatsing leaving screws unisulated. Luckily I realised the problem before running the circuit. So, any ideas? I don't have plasic screws...
thanks in advance
Old 16th April 2005, 12:06 PM   #2
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Default Been there and done that
Use an insulateing washer between the screw and the top of the TO2220 tab. A better plastic would do. You can even cut out a little washer. But be carefull to pick a plastic that does not have to low a melting point like polyethelene. In a pinch you could use a double layer of mica that you have pierced with the proper size hole.
There are fancy bushings that fit in the hole on the tab and allow a screw to pass through all nicely insulated to.
http://www.wiltronics.com.au/catalogue/shop.php?cid=137
MArk
Mark
www.kravchenko-audio.com
Old 16th April 2005, 06:12 PM   #3
have a look at your To220 case to see if it is already insulated.
Some are insulated and look the same shape but have a different case style code.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th April 2005, 10:53 AM   #4
darkfenriz's Avatar
No, it isn't. Middle pins of power transistors are shorted when not isulated.
thanks mwmkravchenko
I'll try this.
best regards
Old 19th April 2005, 11:41 AM   #5
jbateman is offline jbateman  United States
You can use nylon machine screws, and nylon nuts if necessary. You can't apply as much torque to them, but they work ok.
How to isulate screws for to-220?Hide this!Advertise here!
WTB: M5 x 8mm screws dweekie Swap Meet 12 6th February 2009 03:16 AM
SCREWS - where to get them? smellygas Multi-Way 7 28th May 2008 02:04 AM
Speakon screws? MikeHunt79 Parts 12 7th May 2008 09:21 PM
Transit screws pauldyworth Digital Source 0 5th October 2005 09:27 AM
Do I have to use screws busterno1 Multi-Way 8 10th February 2004 08:58 PM
Copyright ©1999-2017 diyAudio
