Can you get a *good* cheap tube amp in HK? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th April 2005, 04:10 AM   #1
Default Can you get a *good* cheap tube amp in HK?
I was after two amps for an active horn system (105 db midbass & 100 db upper end).
The mid bass starts at 250 Hz, and my hearing drops off at 12 kHz, so extension is not needed.
Do any of these Power/ integrated amps available in HK, sound promising options? (prices are approx.)
Kelly tube art Pride 845
6SL7 x 2 , 6SN7 x 2, 845 x 2
NON-feedback 0 db
Class A, 22 W x 2
20 Hz - 35K Hz
CATTYLINK
Melody SP3 USD 650
Power 4 * 5881
12AX7 * 2, 12AU7 * 2, 6922 * 2
38 W x 2
Yarland Pro200SE USD 550
Power 300B
12AX7 * 2, 6SN7 * 2, 5U4G * 1 (rectifier).
Class A, 8 W x 2
LS845B USD 737
845 * 2
6J4P * 2 (rectifiers).
Class A, 22 w * 2.
Yarland FV-34C III integrated
Pre 5670 tube
4 EL84. USD 150!
Opera Cyber-500 monoblocks
300B * 2
6SL7 * 2, 5AR4 * 2
Meixing MC-84A integrated USD 350
13 w *2
EL 84 * 4
12AX7 * 1, 12 AU7 * 2.
Cayin MT12 integrated USD 350
12 w *2
OTK EL 84 * 4
Cheers
good value (i.e. cheap) OPT in uk? adamus Tubes / Valves 6 11th November 2008 08:55 AM
good cheap T4P cartridge? DragonMaster Analogue Source 49 4th July 2007 03:50 AM
Any good cheap old/new CDP's out there to act as Transport? Commited Digital Source 12 21st January 2006 03:53 PM
Good switch for Stepped attentuater, Good cheap RCA jacks pjpoes Parts 20 10th March 2005 08:47 PM
Help? good & cheap SPDIF out for PC net-david Digital Source 6 22nd May 2003 07:38 PM
Copyright 1999-2017 diyAudio
