diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Electrical Transistor question??? (http://www.diyaudio.com/forums/parts/54888-electrical-transistor-question.html)
sbisdabomb 6th April 2005 06:16 PM
I'm from the DIY projector fourms on this site and have a question I thought you guys might beable to help me with.
I have an LCD monitor that I bought broken, backlight doesn't work. I found a surface mounted transistor on the inverter board of the LCD that was humming, looks to be arcing internally. I can't find the actual transistor anywhere (jameco, mouser, digikey, and some others) as expected. The transistor outputs somewhere between 500-2800 volts, and my multimeter can only measure up to 500v. There is an identical transistor on the board and I was wondering if I could put a resistor accross the one that was working - so it ouput less current and voltage, and then calculate what it acutally ouput so I could attempt to find a replacement transistor.
If I'm totally off base here, or in way over my head just let me know.
Thanks in advance guys,
Eric
sbisdabomb 6th April 2005 06:52 PM
It's a transformer not a transistor.
thomas997 6th April 2005 11:54 PM
Is the cold cathode bulb good?
Chances are the transformer will be the same as the ones found in cold cathode computer light inverters.
You can try applying a smaller ac voltage to it and measuring the output to find the ratio.
sbisdabomb 7th April 2005 05:51 AM
yeah the cold cathode is in good shape, it's the transformer that's shot. My buddy is an EE major and has access to all sorts of tools, I think I'm gonna take it to the lab with him and see exacty what it outputs. but any help is still welcom and appreciated.
Copyright 1999-2017 diyAudio
