Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th April 2005, 04:18 PM   #1
Gasho is offline Gasho  Croatia
Gasho's Avatar
Default Audiophyle resistors in signal paths
What is your opinion about sound of diferent types of resistors used in audio electronics (solid state). I know that Dale , Vishay , Draloric , Mills have very good resistors , but they can be very expesive or hard to find/buy.
What experience do you have with Welwyn PCF series and RC55 series of 0.1% precission resistors?
Old 7th April 2005, 01:48 PM   #2
Gasho's Avatar
Anybody?
Old 7th April 2005, 07:23 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I prefer blue spruce planks lightly carbonized in the fireplace (which is rhodium plated, of course).
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 7th April 2005, 07:51 PM   #4
SY's Avatar
0.1% are nice in RIAA networks, but you can achieve the same thing with an impedance bridge or (better yet) a precision inverse RIAA network and liberal use of trimming parts.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th April 2005, 07:58 PM   #5
...and let's take care for the right polarity...
Back to topic:
I am convinced that I am not deaf, but I did not notice
major differences in sound for the small signal resistors.
Even when I was trying to measure the noise of cheap carbon
types versus metalized or metal film types... I could not find a
major difference (Nevertheless I am using ussually the 1% metalized types).
Completely different is the situation in power resistors.
The inductance of wire wound types is not always neglectible.
Sometimes this does not harm....
...sometimes it causes differences in sound ... and somtimes it causes oscillation effects of power amplifiers...
Old 7th April 2005, 11:24 PM   #6
Back to topic:
I'm starting to be convinced that I'm just a deaf idiot. I can't hear a difference between Vishay/Dale RNC55 series and Vishay S102/RNC90Y and Caddock Mk120/MK132/VTxxx. It's actually pretty scary. It might just be that I don't know what to listen for, or the rest of my system isn't of high enough resolution yet.
I've pretty much settled on putting in the resistors that I think *look coolest* for the design. I'm buying some dralorics (partsconnexion has 'em pretty damn cheap at $0.15 in 1-249 qty I think), because they have tight specs AND they're colorful.
I probably just turned the stomache of a lot of tweakers.. I did decide, though, that I like making my stuff with the best possible parts, and spending a little extra for some cool resistors really doesn't bother me Maybe it's just piece of mind knowing that I put some quality stuff in there. Go figure!
Mike
Old 8th April 2005, 07:20 AM   #7
analog_sa's Avatar
just a deaf idiot
No, no. The deaf idiots in my book don't attempt to listen to anything. They much prefer making armchair statements. IF you actually listened and there was no difference then it's cool.
The same approach many (mostly German?) 'high end' companies adopt. A piece of clear acrylic on top is mandatory.
I personally can't afford to spend money on looks. Most of the time tantalums and Rikens are good enough for me.
Old 8th April 2005, 08:31 AM   #8
Originally posted by analog_sa
[B]
Well, I should specify that I have had quite a bit of trauma to my ears over my 26 years.. I've had numerous ear infections, as well as scarring on my ear drums from tubes. But from my hearing tests, I guess my left ear is still in almost perfect shape, while the right is 3db down or so on the high end.
But, I have tried it! I can tell the difference in larger changes, but maybe just not at the resistor level yet. I'm trying to learn what to listen for -- it's definitely hard doing it solo with no experience audiophile(fools?) around to give me the pointers (I only say fools because damnit, we spend too much money on this hobby! It's like crack cocaine!)
Was that tongue-in-cheek? Riken's and tants are like 15-30x more expensive than the dralorics. Sorry, sometimes sarcasm is hard for me to detect over the 'net. The Riken's look cool, tants just look rather pedestrian Not sure how they sound -- from what I've read, there seems to be two camps that tants are either the best or the worst resistors out there.
I haven't tried my Riken's yet.. I have a few waiting to go into some gear. I also have a honkin' load of Corning Glassware Carbon Comp 2% resistors. I bought a few on ebay and these are by far the coolest looking and well-built resistors I've touched. They LOOK military and way over built. I even hit one with a hair dryer from about 2 inches to see how bad it'd drift with temperature and it was only like 30 ohms on a 33k resistor.
I did buy an crapload of Vishay S102/RNC90Y's and various caddocks from surplus sales for pretty cheap to try out. It gives me a warm fuzzy to know I'm putting a $6-$20 resistor in my gear If nothing else, it's great for bragging rights and artificially inflating the value of my home-made gear!
Old 8th April 2005, 11:38 AM   #9
SY's Avatar
No, analog is being serious. He claims to be able to hear all sorts of wonderful things that have escaped both lesser ears and the realm of science. Frankly, I can't hear most of that stuff and think it's most likely self-delusion (analog is very vocal about eschewing any controlled listening test), but that's probably because of my Borg heritage.
Old 8th April 2005, 03:36 PM   #10
analog_sa's Avatar
You nailed this one right SY
what resistors are in the aikido signal path jarthel Tubes / Valves 10 29th June 2006 07:33 AM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 12:47 PM
Latest 6B4G PP and some thoughts about signal return paths... James D. Tubes / Valves 25 8th April 2004 10:46 PM
Signal Capacitors/Resistors StefanJ83 Parts 2 23rd October 2001 06:47 PM
Page generated in 0.11399 seconds (84.84% PHP - 15.16% MySQL) with 10 queries
