Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th April 2005, 12:09 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default OpAmp as a follower, with a resistor from out to -in instead of a wire
I'm working on a project, and I need an opamp used as a follower, but for practical reasons, instead of having a wire from output to -in, there will be a resistor (but no resistor from -in to ground)
Is this worse than a direct connection? Can this cause problems? Is there an optimal value (impedance matching between -in and +in?) ?
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 5th April 2005, 12:37 PM   #2
Did it Himself
richie00boy's Avatar
In a critical application to minimise DC offset due to input bias currents it's actually good practice to put a resistor there that is equal to the impedance seen by the non-inverting input.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 5th April 2005, 02:42 PM   #3
jcx is offline jcx  United States
feedback R in unity gain can be destablizing if the R value is too high and adds phase shift to the feedback path due to op amp input Cin * Rfdbk
depends on the op amp, a few hundred Ohms is usually ok, much higher R and you may need to add a small C in parallel with the R
Old 5th April 2005, 02:49 PM   #4
Bricolo's Avatar
isn't adding a small cap there always a good idea?
Old 7th April 2005, 02:30 PM   #5
00940 is offline 00940  Belgium
if it's just for "practical" reasons, why not using a 0 ohms resistor ?
Ben.
Old 7th April 2005, 05:38 PM   #6
Bricolo's Avatar
the "practical reason" isn't routing the connection
Old 7th April 2005, 06:52 PM   #7
Nicke is offline Nicke  Sweden
Nicke's Avatar
Default Re: OpAmp as a follower, with a resistor from out to -in instead of a wire
Check the data sheet for AD797,that opamp needs a 100ohms resistor in the feedback when used as a follower
Not with an current feedback opamp
Bias resistor for source follower driver SpreadSpectrum Tubes / Valves 11 15th October 2008 03:35 AM
best voltage follower, discrete opamp and whatnot gearheadgene Solid State 79 5th July 2008 12:28 PM
Opamp output resistor.. jethdub Chip Amps 3 21st January 2008 03:46 PM
Source-follower driven by floating opamp only needs low slew rate? Circlotron Solid State 5 12th June 2002 02:06 PM
Page generated in 0.08615 seconds (76.69% PHP - 23.31% MySQL) with 10 queries
