Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd April 2005, 09:49 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default Relay Contact Question
I've gotten this 12 VDC relay for my soft start circuit. As I said, the relay is actuated by 12VDC. However, I can't figure out which actuation terminal (A or B) is +12VDC and which is ground??? Does it matter? I did a quick experiement and it works both ways. Before I randomly pick one orientation I wanted to check with you all to see whether this was normal so that I don't damage the relay inadvertently.
Old 2nd April 2005, 10:09 PM   #2
you can feed dc in either direction.
This relay is taking current all the time the circuit (amp) is on and will run hot.
Try searching for a volt reduction circuit that increases pull-in current and then runs at reduced voltage, about 50% to 70% of rated voltage.
regards Andrew T.
Relay Question SRMcGee Parts 2 31st January 2009 09:03 PM
Newbie Relay Question SRMcGee Parts 13 13th November 2006 02:54 AM
switch or relay question! plz help jaygeorge1979 Parts 6 26th April 2006 01:16 PM
switch relay question jasong Parts 2 5th May 2005 06:42 AM
Page generated in 0.06819 seconds (69.16% PHP - 30.84% MySQL) with 10 queries
