Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
how do you convert 9V to 3.6V
Old 27th March 2005, 12:27 PM   #1
Gizmotech is offline Gizmotech  England
Default how do you convert 9V to 3.6V
how do you convert 9V to 3.6V using resistors and will it work? Any help appreciated. In ther words, how do I do the sums?
Old 27th March 2005, 12:48 PM   #2
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Whatz the required load curent...Whether regulation necessary..
SivanandBalan
Old 27th March 2005, 01:56 PM   #3
Default how do you conver 9V to 3.6V
it's to run 3.6V LED from a 9V battery
Old 27th March 2005, 01:57 PM   #4
paulb is offline paulb  Canada
http://www.allaboutcircuits.com/vol_1/chpt_6/1.html
Note that your load (whatever you need the 3.6V for) is one of the divider resistors. You need to know its resistance, or how much current it draws at 3.6V (R=V/I). If the load changes (draws more or less current), its voltage will also change. Using resistors only to drop voltage has no voltage regulation characteristic.
Old 27th March 2005, 02:08 PM   #5
sivan_and's Avatar
Many options:
Constant current source or Exotic LED drivers (white) from National.com or ti.com texas inst
Or simple current limitting resistor>>>>9-3.6/ LED current in milliamp = resistance in Kohms.
For 10ma LED Current R=540 OHMS (560 OHMS nearest commercial value)
SivanandBalan
Old 27th March 2005, 05:44 PM   #6
Shoog is offline Shoog
Shoog's Avatar
If all you are doing is lighting a few LEDs then use a simple series resistor to derive the correct current. The total voltage across the arrangement is totally unimportant, its the current that counts.
Shoog
Old 27th March 2005, 05:51 PM   #7
lgreen is offline lgreen  United States
lgreen's Avatar
Default LED Equation
The LED equation is here.
Just use 1 resistor in series, use the formula.
For a typical amber LED Vf is about 2V, and If is about 20mA. So for 9V I get 350 ohms. To be safe, I'd use 500 or 1K. They get pretty bright even without using them to their max specs.
how do you convert 9V to 3.6VHide this!Advertise here!
Convert RCA box to XLR (phono) Doctorcilantro Analog Line Level 3 20th August 2008 07:01 PM
Can I convert LPs to CDs? pendel Everything Else 22 13th November 2007 05:27 PM
How to convert VGA to TV pasan Digital Source 4 30th March 2007 11:58 AM
Convert 230 VAC amp to 120 VAC?? chuck55 Solid State 8 7th February 2006 01:22 PM
XLR Mic, how can I convert it to assymetric? Bricolo Analogue Source 8 23rd January 2004 04:34 PM
Copyright ©1999-2017 diyAudio
