Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th March 2005, 02:24 PM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Question LM7171 for audio
If a LM7171 is use for audio application and limited its'bandwith not more than 160kHz,will it:
1)oscillate?
2)produce more noise?
3)sound terrible?
I dont mind any replies even with theory only.All are welcomes!Just try to get some advices.
Old 24th March 2005, 07:18 PM   #2
macboy is offline macboy  Canada
Concerning noise:
This opamp is spec'd at 14.5 nV/sqrt(Hz), which actually doesn't seem too bad for audio use (many audio opamps are less than 5 though). However, when reading specifications, you need to be aware that things are not always as they seem. In fact, the noise of this opamp is higher at audio frequencies (not a surprise since it isn't intended for use at audio frequencies, but up in the MHz range). And not just a little higher... it's at lot higher. See the datasheet for details. In addition to increasing voltage noise at lower frequencies, it also has increasing current noise at lower frequencies too. This is an important consideration since (depending on your input impedances) it can contribute as much or more noise than the voltage noise figure does.
There is a good chance that you will find this opamp to be too noisy for audio use.
Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? tiefbassuebertr Solid State 43 22nd January 2012 12:50 PM
Ad811 Vs. Lm7171?? mfahimi Chip Amps 2 9th August 2009 09:32 AM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
[UK] 2x Pro Audio C12 - 300MB & 2x Pro Audio PST888 Tweeters for Sale makksus Swap Meet 0 3rd November 2008 12:12 PM
Page generated in 0.05688 seconds (74.24% PHP - 25.76% MySQL) with 10 queries
