Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd March 2005, 04:15 AM   #1
franjy is offline franjy  United States
Default using steel chassis as ground
Interested in a transformer based passive preamp from Elecro-print that uses the steel case as ground (negative) for all input, output and potentiometer connections. The female chassis output RCA's have only a positive interconnect cable and use the chassis connection as ground. How does this compare to 2 wire connections, aluminum case, isolated components and no chassis ground. This is how my present non-transformer passive is constructed and I have no hum problems. Using a case instead of wire concerns me.
Old 23rd March 2005, 07:06 AM   #2
You must connect the mains safety earth to the steel chassis, no other option is permissible. Some manufacturers connect each removable metal panel with a flexible cord (wire) back to safety earth or adjacent fixed panel for added safety.
Many manufacturers and DIY isolate the chassis from signal and power ground. It helps stop hum and buzzing contaminating the signal ground and therefore your output should be cleaner.
A few do make direct connection from chassis to ground, but I have tried a few versions of this and none have been successful.
I recommend separate power ground, signal ground and final single wire between. A separate safety ground with 10R connection to power ground.
regards Andrew T.
Old 23rd March 2005, 07:58 AM   #3
Did it Himself
richie00boy's Avatar
Your current isolated socket version with alu case is far superior as far as a connection scheme goes. Using the case as ground creates huge potential for local ground loops and this is exacerbated by the steel case which will support eddy currents. Quite poor design IMO.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 23rd March 2005, 04:57 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: using steel chassis as ground
Originally posted by franjy
passive preamp
Huh?
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 23rd March 2005, 08:24 PM   #5
Default Andrew T
This is a PASSIVE preamp. There is no real current here. except for the 2 volts the transformers see from a CD player. I don't think the same grounding concerns apply.
Aluminium vs steel chassis Rob11966 Tubes / Valves 86 22nd January 2009 04:45 PM
DIY Steel Chassis GlidingDutchman Everything Else 4 2nd August 2008 07:11 AM
How to paint al/steel chassis? protos Parts 14 18th May 2006 11:03 AM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 01:08 AM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 3 28th February 2003 05:31 PM
Page generated in 0.08610 seconds (77.87% PHP - 22.13% MySQL) with 10 queries
