Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd March 2005, 03:24 AM   #1
crippledchicken's Avatar
Question upgrade for BA4560N OP AMPS
hi there, anyone know of any upgrade op amps for these dual inline, op amps? thanks, crippledchicken
Old 23rd March 2005, 01:24 PM   #2
macboy is offline macboy  Canada
4560 are pretty low end.
Try any of the usual suspects: NE5532, OPA2604, OPA2132, OPA2134, or even LM833, NJM4580 (I like the clone made by Texas Instruments, RC4580) willl be an improvement. Some people like high speed opamps such as LM6172, which were not specifially designed for audio but work of course. They are usually noisier than the audio types and can be finicky about layout, oscillating rather easilly. Since you are replacing opamps in an existing circuit and have no control over circuit layout, you should probably stay away from such things unless you are feeling especially adventurous, and know how to test for oscillating and how to correct it. Seaching these forums on the part numbers above will yield many many posts on the topic of opamp replacements.
Old 23rd March 2005, 01:47 PM   #3
hi macboy, thanks for the response. i guess i should have mentioned that these are in a sub plate amp. i'm familiar and have used most of the amps youv'e suggested but, my problem is, these are 8 pin inline, instead of the usual 4 pins per side? or are some of the mentioned op amps also, available in the inline type package? thanks again, crippledchicken
Old 23rd March 2005, 01:59 PM   #4
Default BA4560N SIP8 package mcboy maybe this will help
i found this info on package type
Old 23rd March 2005, 02:50 PM   #5
Not many opamps are available in a sip8 package.
But there is a trick you can do to use a quad opamp in place of the sip-8 dual opamp. You'll notice that the seven pins on one side of a quad opamp are laid out the same as 7 of the 8 pins of a sip-8 package. So take a quad opamp, 'flatten' it out, and cut off all the pins on one side, except the power supply pin, which you'll have to connect with a wire to the 8th pin hole.
Quad opamps include OPA4132, OPA4134, and LM837.
Another alternative is to buy (or make) a sip convertor. You may be able to find at suitable soic-to-sip unit at Dig-key here. (note that I searched on Digi-key Canada's site, so those are Canadian prices).
Old 23rd March 2005, 02:56 PM   #6
WOW! very nifty trick i'll have to check into that. thanks alot, crippledchicken
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
Replacement for BA4560N? Netlist Chip Amps 4 11th April 2007 06:55 PM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 18 31st August 2006 10:39 AM
Page generated in 0.08921 seconds (79.50% PHP - 20.50% MySQL) with 10 queries
