| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi everyone, i am very new to audio, but i was hoping for some advice.
i picked up a used Arcam Alpha 7 Integrated amp that is not working entirely well. The unit powers up and the preamp component works when i hook it up to an external power amp. However, the unit's amp section does not appear to be working at all. the unit has 2 sets of speaker outputs and a headphone jack, none of which are working. i opened it up and one of the fuses was blown. it uses a small 2.5A/250V fuse, so i replaced that with a 2A/250V fuse. as soon as i turned on the power, the fuse blew. i thought maybe i didn't have it fit properly, so i carefully inserted another one and had the same result. any suggestions on what may be the problem? is it simply the fuse or likely something else? since i'm here, are there any simple tweaks that would improve this amp since i've got the unit open? thanks in advance. |
#2 |
sounds like a shorted output component or, maybe power supply
| Arcam Alpha blows PSU fuse | twosheds | Solid State | 42 | 27th August 2008 06:31 AM |
| Arcam Alpha 6 Integrated | bulgin | Solid State | 1 | 18th November 2006 01:12 PM |
| Arcam Alpha- fuse keeps blowing | ash_dac | Solid State | 15 | 17th June 2005 05:31 PM |
| Arcam Alpha 5+ Fuse | Fraser | Solid State | 3 | 13th March 2004 03:57 PM |
| Page generated in 0.05760 seconds (71.15% PHP - 28.85% MySQL) with 10 queries |
