Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd March 2005, 02:59 PM   #1
ManUtd is offline ManUtd  Norway
ManUtd's Avatar
Default Doxa 70 SE Amplifier
Hi All!
I am about to change a defective transistor inside this amlifier.
One channel has 6pcs BD246C and 6pcs BD245C.
Those six are coupled in paralell.
I need to replace one piece of BD245C.
I have at hand TIP35C,BD249C and some 2sc**** 2SD****
Can they be used as replacement in this case?
Thanks for Your comments.,
ManUtd.
Old 22nd March 2005, 06:11 PM   #2
PMik is offline PMik  United States
PMik's Avatar
you need to use pairs of TIP35C/TIP36C ....if you mount just one single TIP35C, the outcome will be unsure.
Mod is fun
Old 22nd March 2005, 08:00 PM   #3
ManUtd's Avatar
Pairs?
There is six of each(BD246C and BD245C) in paralell.
But could i use eg. 6* BD246C and 6*TIP35C ?
Old 22nd March 2005, 08:53 PM   #4
PMik's Avatar
Exactly...they are the nearest replacement for the BD245/BD246
The TIP's have better specs compared with the BD's ...it will be an upgrade
Mod is fun
Old 22nd March 2005, 09:16 PM   #5
ManUtd's Avatar
Thanks,
Already ordered 6 pcs TIP33C.
I think this is correct replacement for BD245C.
And i leave BD246C as it is,no change.
Old 22nd March 2005, 09:53 PM   #6
PMik's Avatar
Im sry to say, but i think its a really sad event
when you spoile
a really nice amplifire, by saving very! few bucks
Mod is fun
Old 22nd March 2005, 10:45 PM   #7
ManUtd's Avatar
What do You mean?
TIP33C is a direct replacement for BD245C.
This amp was Originally built for BD245C and BD246C and it sounds well
with those transistors as well.
Why is will it sound better with TIP35C,TIP36C ???
Please advice why.
ManUtd.
when you spoile
Old 23rd March 2005, 05:45 AM   #8
PMik's Avatar
What i mean is to use two different Types, brands of semiconductors, will for sure raise the THD
I have heard the amp you got....its one of the better ones, and afir ....its uses low global feed-back .....you have to make it as symetrical as possible to keep or better improve specs, this is crucial point.
Other types of power-transistors besides the TIP/BD's could be used ....But the TIP's are the cheapest of them all
Mod is fun
Old 23rd March 2005, 07:45 AM   #9
ManUtd's Avatar
Thanks Pmik,
I think i understand.
If i change to TIP33C instead of BD245C i should also change BD246C to TIP34C in the same time?
Then there is a matching pair again?
Reg,
ManUtd.
Old 23rd March 2005, 05:14 PM   #10
PMik's Avatar
Yeah! keep it "clean" by replacing parts symetrical, if you cant get a part .....you have to replace in both channals...this is not a cheap amp...it was made for wanna be/have high End gear users
Ps. Audio 60 made by the same engineer, was also a nice "bang for bucks" amplifire
Mod is fun
Doxa 70 Clone valo Solid State 24 13th August 2011 10:17 PM
Doxa 70 Se Schematic?? kimschips Solid State 18 14th April 2009 07:53 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.11018 seconds (81.00% PHP - 19.00% MySQL) with 10 queries
