Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd March 2005, 07:56 AM   #1
noyan is offline noyan  Turkey
Send a message via Yahoo to noyan
Default Potentiometer with loudness tap
I am now building a Mcintosh C22 tube preamplifier. I need to find 800k potentiometers with loudness tap, for volume control. Any idea how to provide them?
Thanks.
Old 22nd March 2005, 08:14 AM   #2
Hennie is offline Hennie  South Africa
The Vishay P11/PA11 modular series includes a centre tap option. Not available in 800K though:
See http://www.vishay.com/docs/51031/p11.pdf
Danish Audio Connect does a stepped attenuator which is available up to 500k. You can probably modify / rework this to add a loudness tap at any convenient position.
See http://www.dact.com/Attenuator_data_sheet.PDF.
Old 22nd March 2005, 09:46 AM   #3
Default loudness tapped pots
Thanks but i checked those sites and i could not see any loudness tapped pot.
Old 22nd March 2005, 10:21 AM   #4
The Vishay range I referred to definitely includes a centre tap option. It is in the data sheet. While a centre tap is not ideal, it can be made to work.
To me it looks like the DACT attenuator consists of a series resistor network. If so, it should be easy to modify it to provide a tap at a suitable position.
The loudness war.... Empee Everything Else 81 19th November 2008 01:37 PM
How much loudness is enough for HT? Phil Olson Multi-Way 19 29th March 2008 12:14 AM
three tap loudness pot adason Parts 8 26th January 2006 08:53 AM
Potentiometer loudness tap? paulb Solid State 3 13th May 2002 07:54 PM
Page generated in 0.06529 seconds (75.15% PHP - 24.85% MySQL) with 10 queries
