| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 |
Electrons are yellow and more is better!
Those amps are nice examples of SMT parts.
http://groundsound.com/images/pa3cc_l.jpg http://groundsound.com http://mirand.dk/smallheats3.jpg http://mirand.dk
/Per-Anders (my first name) or P-A as my friends call me |
#32 |
diyAudio Moderator Emeritus
Metal film surface mount resistors are certainly fine for all audio applications. Thick film SM resistors are ok too for less critical use and are much cheaper than metal films. If you want precise gain matching go for the 1% or tighter tolerance metal films.
As has been mentioned here and there on this forum, ceramic SM caps with NP0 or C0G dielectric are fine for all audio applications. X7R and other dielectrics aren't as good as NP0/C0G, but work fine for decoupling.
Brian |
#33 |
I love SMT for prototyping because I can avoid all that tedious drilling ...
I have no trouble hand assembling SMT (0603, 0402, QFP etc), even with a fat, butcherous iron. Its all in the technique. And if you want to parallel resistors, SMTs just stack on top of each other! All those complaints about Tc etc apply equally to leaded parts - its not specific to SMT . |
#34 |
I like the idea of SMT mounted parts, especially the benefit of having a reduced foot print. Soldering can be a challenge, but it is doable.
But my big complaint with SMT is that the resistor and cap ends can easily snap loose if the board gets bent or twisted a little bit.
Writing is good exercize for the texticles! |
#35 | |
#36 | |
Brian |
#37 |
Is there a better way to solder SMD other than soldering on end and then soldering the other end? Does it pay to dispense solder paste then glue the SMDs on to the PCB, then pass it thru a "reflow" owen.
I use home owen to smooth out the solder joints but I wonder about the use of solder paste. Any wisdom out there?
Koolkid |
#38 | |
Tube of solder paste from digikey is ~$50 if you want to try it out. No need to glue the parts down if you are careful. |
#39 | |||
Brian |
#40 |
Thx for the replies.
I haven't tried solder paste because of the need to dispense it onto the pads, in small droplets (????) then to place the SMDs, all of them. What if I hit the boards and dislocated some SMDs? I would have to reposition them again, wouldn't I. Plus solder paste seems expensive. I bought some but never got around to use it and it's expired by now, most likely (I haven't dared opening the vial!) I looked at some sites on SMD soldering. They seem to use just solder wire, like what I still do. Why should one remove flux with isopropanol? for reliability? to prevent further chemical reaction? (acid attack?)
Koolkid |
| Surface mount components! | ungie | Swap Meet | 12 | 25th September 2009 01:41 PM |
| Surface mount components for analogue audio... Yes or no??? | Pilbromatic | Parts | 26 | 6th August 2009 04:59 AM |
| Surface mount drive components? | ak_47_boy | Class D | 3 | 10th June 2008 06:53 AM |
| Soldering Surface Mount Components | Ulas | Digital Source | 2 | 14th April 2006 02:38 AM |
| Page generated in 0.12095 seconds (80.59% PHP - 19.41% MySQL) with 11 queries |
